HQ Brake conversion Tutorial
Posted 04 June 2007 - 05:32 PM
Does anyone know of a tutorial for the conversion to HQ brakes on a LX torana.Ive had a bit of a look around but no luck......
Weedy
#3 _Squarepants_
Posted 04 June 2007 - 11:15 PM
Posted 05 June 2007 - 08:09 PM
Well I guess that depends on how you go about it.HQ brake conversion will throw your steering geometry out.
#5 _Squarepants_
Posted 13 June 2007 - 05:24 PM
I'd be interested to learn more as (obviously I'm no expert and) this is what I've been told and it's the only reason I didn't do it myself.
Can you use HJ or HZ Brakes or are they different to HQ?
Someone once told me to use HJ stubs and discs and UC callipers, does this sound feasable?
Please, tell me (or link me to) everything you can, as it would be a hell of a lot cheaper than a Hoppers kit.
Posted 13 June 2007 - 10:09 PM
Remove the Torana caliper and disc. Take your HQ discs to the brake shop and get them to remove about 6mm or a quarter inch from the external diameter of the disc and get the disc face machined down all the way to the bolt up face (most HQ discs dont have this face fully machined as the pad normally doesn't run in this area). Fit these discs to the stub axles on your car and repack the bearings (HQ and LH/X/UC bearings are the same). Trial fit the HQ caliper and check for interference (yes the HQ caliper will bolt to the torana stub) and grind away as required to clear the tie rod end. Check the clearance between the outer pad and the bolt up face of the disc (you have moved the caliper closer to the bearing than it would be in an HQ). Refit, bleed brakes and drive off !!!
Yes the caliper does not sit as far away from the spindle as it does in an HQ but you do have ventilated discs, a real caliper, HQ pattern and no wheel alignment or bumpsteer issues. Try it , you'll like it.
Flame on non believers !!!!!!!!
Posted 13 June 2007 - 11:06 PM
Thats exactly what Brock used on the yellow LJ he campaigned in the Biante series a couple of years ago
It works
Its cheap
One of many ways to upgrade your brakes
Not a huge step.... but certainly a step in the right direction
#8 _Squarepants_
Posted 15 June 2007 - 01:38 PM
When you say "check the clearance between outer pad and bolt up face", how tight is this likely to be, and what do you do if it interferes? And what do you mean by "a real caliper"? Do you mean they're bigger? They're still single piston aren't they?
#9 _Herne_
Posted 15 June 2007 - 02:19 PM
Thats exactly what I have and it passed engineering with no worries at all.I'm sure I will upset a few people but after doing a heap of HQ/LH/X brake conversions this is how I now do it.
I have no complaints with my brakes.
Herne
#10 _Herne_
Posted 15 June 2007 - 02:37 PM
I didn't think it was commonly known that Brock raced with this very same brake conversionStruggler you will get no fight from me on this one
It works
Its cheap
I have received funny looks of doubt when this has been mentioned in passing conversation.
Herne
Posted 15 June 2007 - 02:44 PM
That clearance is usually fine, but I have ground a bit off a loose pad once before.When you say "check the clearance between outer pad and bolt up face", how tight is this likely to be, and what do you do if it interferes? And what do you mean by "a real caliper"?
By a real caliper I mean one that takes a good size pad, is fairly stout and flex resistant. I really don't like the alloy LX calipers that some use in the conversion with a steel HX slide.
Posted 15 June 2007 - 08:13 PM
I notice such thingsI didn't think it was commonly known that Brock raced with this very same brake conversionStruggler you will get no fight from me on this one
It works
Its cheap
Herne
Posted 15 June 2007 - 08:51 PM
#14 _rorym_
Posted 15 June 2007 - 10:37 PM
Posted 16 June 2007 - 10:08 AM
Posted 16 June 2007 - 10:31 AM
#17 _SLR Goat_
Posted 16 June 2007 - 11:35 AM
cheers dennis
Edited by SLR Goat, 16 June 2007 - 11:36 AM.
Posted 16 June 2007 - 12:23 PM
#19 _SLR Goat_
Posted 16 June 2007 - 12:43 PM
Just another query u obviously run the calipers on the front of the rotor how much grinding is required to clear tie rod end i got uc steering arms atm but thinking of changing it so the suspension geometry will be standard again
Do u have to get custom made flexi hoses made up or is there a random hose that will fit i have a LH
cheers dennis
Posted 16 June 2007 - 02:00 PM
From memory I just used the HQ hoses.
#21 _shmack_1_
Posted 16 June 2007 - 06:08 PM
dattoman, what are some better options without the hoppers kit obviously,?
Edited by shmack_1, 16 June 2007 - 06:10 PM.
#22
Posted 16 June 2007 - 07:11 PM
Either as above
Or HQ stubs and brakes and A9X steering arms
Or our kits
#23 _shmack_1_
Posted 17 June 2007 - 01:35 AM
#24
Posted 17 June 2007 - 12:08 PM
I know I'm answering Dattomans question, I'm sure he will chip in and I don't mean to tread on his toes.Is the hq harrop arms option any better than the above in your opinion?
Using the HQ stub moves the caliper further away from the centre of the disc, this increases braking leverage and is better than the above described method. It is more expensive though as you must buy the Harrop arms.
Yes it is a better, more expensive option.
JMHO
#25 _why-psi_
Posted 18 June 2007 - 11:21 AM
