Identification M20 and M21
43 replies to this topic
#1 LC-069
LC-069
  • 363 posts
  • Name:Mark
  • Car:LC GTR & LX SL
Posted 06 February 2006 - 04:49 PM
I know this has been done before but
how do you identify a m20 and m21??
Just pulled apart my gearbox and on the cluster gear is has:
HOLDEN 2813498 AP
on the casing 9938391
Thanks guys
#2 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 06 February 2006 - 05:38 PM
There is an id list in the current street machine....the ratios define what is what.
#3 _Yella SLuR_
_Yella SLuR_
Posted 06 February 2006 - 09:02 PM
Or simple way by the input shaft. One groove --> M20, Two grooves --> M21. Forget the number of grooves for M22, but think it is two as well, but different ratios.
Edited by Yella SLuR, 06 February 2006 - 09:02 PM.
#4 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 06 February 2006 - 09:07 PM
To unreliable Pat. From personal experience.
#5 _Yella SLuR_
_Yella SLuR_
Posted 06 February 2006 - 10:30 PM
Any fail safe way to ID them Craig? Would be interested to know, particularly following some drawn out debates on the old site regarding the M22 and/or Rockcrushers. For those that will get excited again, I didn't mention the M22 OK.
#6 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 07 February 2006 - 03:39 PM
I have the SM article in from of me...They say:
Grooves.
M21 = 1 groove
M20 = 2 grooves
Ratios
M21 (M22 also)
1st 2.20:1
2nd 1.64:1
3rd 1.24:1
4th 1:1
M20
1st 2.52:1
2nd 1.89:1
3rd 1.46:1
4th 1:1
I will compare this to varios Holden publications I have at home (when i get home tomorrow night)
Feel free to comment....as I think Street Machine have stuffed it up..again
#7 Dr Terry
Dr Terry
  • 3,347 posts
Posted 07 February 2006 - 08:20 PM
Hi Guys.
The part number that LC-069 quotes gives it away. He quotes '2813498' which doesn't exist, but is easily misread & should be 2813496. This is the cluster gear for the standard ratio (M20) box.
The 2813497 cluster is the M21 type but this could not be misread as 498, could it ?
The ratios that FastEHolden has listed are for Chevy Saginaw boxes & are no relation to the M20/M21/M22 Holden 4 speeds.
Dr Terry.
#8 Toranavista
Toranavista
  • 2,862 posts
Posted 07 February 2006 - 08:21 PM
The only way to know what you are buying is to remove the inspection cover and check the number on the cluster gear.
M20 is 496
M20 (XUI) is 899
M21 V 8 cluster is 497.
M21 optional L34 and XU1 is 484
Info taken from old forums
#9 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 07 February 2006 - 09:21 PM
I think that means the doc has confirmed SM have f@cked it up again.
I will post the correct ratios according to Holden when I get home..unless someone beats me.
#10 _lexa_
_lexa_
Posted 07 February 2006 - 10:14 PM
while we're at it...anyone know how to identify between a celica and a supra box?
#11 _redrana_
_redrana_
Posted 28 May 2006 - 05:29 PM
Hi, I've recently bought a gearbox that I hoped was an M21 but didn't check the part number on the cluster before handing over the cash. It was cheap anyway so not too worried about that but would appreciate some help identifying what I got.
It doesn't have any of the numbers quoted earlier in this thread but has the following on the cluster:
Holden 2820694 L70
There is a serial? number stamped into the case that is T798589
Input shaft is 10 spline with no distinct grooves - there is a slight change in thickness about 3/4 way down the shaft.
Could it be a later M21 or M20 from a Commodore?
Any help would be great
#12 _rorym_
Posted 28 May 2006 - 05:41 PM
Torana Vista is spot on..I had all the numbers somewhere including the M22...Forget the rest..and...NEVER listen to Street Machine..they are running at 95% failure on information so far from what I have seen. I am sure it is reprint stuff from the States that no one checks and unless you have an american car is bloody useless.
#13 LC69GTR
LC69GTR
  • 2,761 posts
Posted 28 May 2006 - 05:46 PM
While we a talking about gear boxes what does the number 5 stamped on it mean and the yellow writing painted on that say's AS what does it mean ?
#14 _LX8VD69_
_LX8VD69_
Posted 28 May 2006 - 05:55 PM
i thought that SM had it back to front as i have a six cyl aussie 4 with 1 groove and to the best of my knowledge there was never a 6 cyl M21, but i could be wrong
#15 _lx5008_
_lx5008_
Posted 28 May 2006 - 05:58 PM
694 cluster gear number is a holden one tonner gearbox. which is what i call the m22. only the one tonners both 6 and 8 cylinders had these boxes.
#16 _Oldn64_
_Oldn64_
Posted 28 May 2006 - 06:15 PM
Ok agree with lx5008 and Dr Terry.
WILL PEOPLE FORGET THE BLOODY GROOVES. The only way to id these is the input part number and teh cluster part number. The clusters are as listed above. The input shaft and the cluster gear mate as a pair (ie you cannot have a m21 input with a m20 cluster or vise versa otherwise you will detonate first gear pretty quickly.
M22's are great fun for towing, or doing heavy work. First gear is rediculous and almost unusable, and hence was fitted to the commericals. this gets the vehicle moving and then uses teh torque in second to bring the car up to speed. From memory the M22 has same gearset (2,3,4 not first obviously) as teh M20, thus you end up with a big gap between 1st and 2nd and gap between 2nd and 3rd. 4th is nice once you are in it.
Keep in mind that with these boxes that there is no strength difference in them whatso ever, so if you are trying to upgrade from a M20 to a m21 for "it is stronger mate" then do not be mislead, all you are doing is getting a different gear set and thus a slightly nicer gear spacing.
Just in the M21 sets there are inputs with zero grooves, 1 groove and 2 grooves. next to useless when the M20 have 1 and zero aswell.....
#17 _redrana_
_redrana_
Posted 28 May 2006 - 06:31 PM
Hi Oldn64 this is probably a silly question but in your info above about gearbox strength did you mean that the M22 was also the same strength as the M20 and M21 or were you just referring to the M20 and M21 being the same strength? Thanks
#18 Toranavista
Toranavista
  • 2,862 posts
Posted 29 May 2006 - 08:03 PM
In terms of relative strength the M22 is considered stronger. The strength is attributed to the gears being cut straighter. The downside is it is a noisy box.
#19 Dangerous
Dangerous
  • 948 posts
Posted 29 May 2006 - 08:25 PM
Yep, forget the grooves. Without taking the inspection plate off, whack it into first, and turn the input shaft while counting the output shaft revolutions. 3.05 turns of the input shaft to 1 turn of the output shaft = it's an m20. 2.54 turns means it's an M21. Can't remember M22 first gear ratio, but it's significantly higher than 3.05:1 - up around the 3.5??. L34 close ratio Aussie 4 speed is 2.32:1, and rare as all Hell (think these ratios were homologated for the XU-1 as well). This info is irrespective of whether it's a 6 or an 8 box.
#20 _lx5008_
_lx5008_
Posted 29 May 2006 - 09:33 PM
hi all just thought i would post the gearbox part munbers for everyone.
some other people have shown ratios so here are the part numbers.
gearbox part numbers
#21 _82911_
_82911_
Posted 30 May 2006 - 10:34 AM
That would be the Muncie Rockcrusher you are referring to...NOT the "aussie M22. :D
Cheers Greg..
#22 Dr Terry
Dr Terry
  • 3,347 posts
Posted 30 May 2006 - 12:20 PM
Hi Guys.
I thought it�s time to put in my 2c worth on the topic of Aussie 4-speeds.
Firstly, the use of the terms M20 & M21 & so on, is very confusing. The 1 code number can refer to more than 1 type of box, so it�s better not to rely on them. For instance an M20 is also an Opel 4-speed, an M21 is a Saginaw, the M22 is another Saginaw & M22 is also what GM in the US call their Hi-Torque Muncie �Rock-Crusher� box. The box in the XU-1 is called an M20 even though its ratios are closer to what we normally call an M21. See what I mean!!
Anyway there are 5 different ratio sets available in the Aussie 4-speed. They are:-
3.05/2.19/1.51/1.00 (Cluster Part No. 2813496) This is the most common version (normally called the M20) & is available with both 6 & V8 front shaft lengths.
2.54/1.83/1.38/1.00 (Cluster Part No. 2813497) This is probably the 2nd most common box & is standard fitment behind 308/5.0 V8s (normally called the M21) & is usually only seen with a V8 length front shaft, although there was a 6-cylinder version homologated as a alternate choice of ratios for the LJ XU-1.
3.74/2.68/1.68/1.00 (Cluster Part No. 2820694) This is the �wide ratio� box (normally called the M22) that is usually only seen in 6-cylinder HQ-WB One-Tonners. It was only ever factory built with a 6-cylinder length front shaft, but since the clutch gear is the same as an M15 3-speed box, you could use an M15 V8 front shaft & make a V8 M22 if you really needed one.
2.54/1.83/1.25/1.00 (Cluster Part No. 2823899) This is the box that is often wrongly referred to as the 6-cylinder M21, when it was actually called the XU-1 M20 (by GM-H). It was standard issue in XU-1s (with a 6-cylinder front shaft, obviously) but the same ratio set was also homologated as an alternate unit for racing for the L34 (with a V8 length front shaft).
2.54/1.65/1.25/1.00 (Cluster Part No. 9939484) This is probably the rarest box of all, as it was only seen as an homologated alternate unit for the LJ XU-1 & the LH L34, with their respective 6-cylinder & V8 length front shafts.
Another common myth to dispel is that there is no difference in strength between any of these boxes, they all use the same bearings & casing etc. A V8 M21 is no stronger than a 6-cylinder M20. The M22 is not stronger just because it�s a One Tonner Box. Also, as mentioned in an earlier post using the ID grooves on the front shaft is not reliable.
Hope this adds to the confusion.
Dr Terry.
#23 Dangerous
Dangerous
  • 948 posts
Posted 30 May 2006 - 02:45 PM
Gotta love it with all that good info in one post. Thanks Doc. One question though - the last gearbox ratios that you quote for the rare option on L34 and LJ XU-1 - shouldn't that have a 2.32:1 first gear ratio, not a 2.54???
Also for clarity, as I understand it, the "XU-1 M20" was standard on XU-1's from the Bathurst 1971 LC production run onwards through all of the LJ XU-1s, with earlier LCs having the Opel box. Is that the case?
#24 Dr Terry
Dr Terry
  • 3,347 posts
Posted 30 May 2006 - 03:38 PM
Hi Dangerous.
Yes, my mistake, a bit of a slip with the copy & paste. The 1st gear in the last one was 2.32.
AFAIK the XU-1 M20 was fitted to all CK XU-1s in the LC as well as being standard in the LJ XU-1s. The Opel M20 was fitted to all GTR & XU-1s prior to July '71.
Dr Terry.
#25 _Oldn64_
_Oldn64_
Posted 31 May 2006 - 01:00 AM
Again agree with teh doc, as the info is spot on. It is important to remember with this that the main case is also the same for the all syncro 3 speed box. the humble aussie four was created from the bedford three speed. Again holden at its best parts bin selection. ;)
