steering arm id required
20 replies to this topic
#1 _SLR Goat_
_SLR Goat_
Posted 28 January 2009 - 06:37 PM
Can anyone tell if these r UC steering arms just by looking at the pic
#2 76lxhatch
  • 7,219 posts
Posted 28 January 2009 - 07:55 PM
Part numbers would be good but looking at the pic I think they are, because if you draw a straight line through the mounting holes the part where the tie rod end attaches isn't close to parallel and drops down a fair way. But don't take my word for it!
#3 76lxhatch
  • 7,219 posts
Posted 28 January 2009 - 07:58 PM
Bugger I might have that backwards, see this:
http://www.gmh-toran.......st&p=128584
#4 _SLR Goat_
_SLR Goat_
Posted 28 January 2009 - 08:29 PM
clean set have already being id as lx but always safe it check will find/clean of shit of other set but i think they both may be lx
#5 _rorym_
Posted 28 January 2009 - 08:33 PM
Find a std LH/X one and compare. If they are UC I will have both lots Dennis...I am experimenting with a 10 tonne press to make A9X ones.
#6 _rorym_
Posted 28 January 2009 - 08:38 PM
Reckon youre right...they look LX.
#7 _SLR Goat_
_SLR Goat_
Posted 28 January 2009 - 08:47 PM
Gunna take wheel off my uc tomorrow and compare lol u wanna try the experiment with lx arms.........
#8 _rorym_
Posted 28 January 2009 - 08:58 PM
UC are easier...just needs a 10 degree bend down.
#9 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 29 January 2009 - 01:11 AM
The UC steering arm part numbers are LH 9928329(GM8329) & RH 9928328(GM8328).
The LX steering arm part numbers are LH 9947249(GM7249) & RH 9947248(GM7248).
#10 _lx-304_
_lx-304_
Posted 29 January 2009 - 06:39 AM
im abit confused,the arms in the photo are the same ones i posted the numbers for a couple of days back.they wre given to me as uc,yet they are the same as my 76 lx.the results came up as lx right hand side .
now its a uc.
which are they
dave
#11 _rorym_
Posted 29 January 2009 - 07:08 AM
What are the numbers?
#12 _lx-304_
_lx-304_
Posted 29 January 2009 - 07:47 AM
the numbers are the ones fuzzy says is uc.the thread is a couple down from the top.gm 8329
dave
#13 76lxhatch
  • 7,219 posts
Posted 29 January 2009 - 08:55 AM
I think he may have got it backwards, my LX catalogue says LH 9928329 and RH 9928328
#14 _rorym_
Posted 29 January 2009 - 09:11 AM
Fuzzy....confirm...??
#15 _brett_32i_
_brett_32i_
Posted 29 January 2009 - 09:33 AM
rory
it looks like the a9x are actually longer than the uc in that pic. could you maybe trace around the 2 (or 3) of them, keeping the mounting holes in the same spot, so we can get a better idea of what is happening.
what will your mod achieve? is it clearance for calliper or improvement in bump steer?
#16 _rorym_
Posted 29 January 2009 - 11:38 AM
Brett...not mine...stole the pic off Dangerous...Its a bumpsteer thing but M@ says the difference between A9X and UC is minuscule.
#17 _rorym_
Posted 29 January 2009 - 11:41 AM
Comparison of UC and A9X one mounted on the A9X stub axle. Pretty close - definitely better than using an LX one.
#18 _rorym_
Posted 29 January 2009 - 11:45 AM
From M@s thread.
I have just done the Std A9X bumpsteer and it is the best of the standard Torana setups - only just slightly better than the UC bumpsteer but bugger all in it.
M@
#19 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 29 January 2009 - 04:36 PM
YES SORRY I got them switched around reading the superseeded numbers the wrong way round in the UC catalogue :fool: .
CORRECT INFORMATION is:
The UC steering arm part numbers are LH 9947249(GM7249) & RH 9947248(GM7248).
The LX steering arm part numbers are LH 9928329(GM8329) & RH 9928328(GM8328).
My apologize to all , I blame the heat , bloddy hot in Melbourne.
Edited by fuzzypumper, 29 January 2009 - 04:37 PM.
#20 _SLR Goat_
_SLR Goat_
Posted 29 January 2009 - 06:15 PM
Okay got the numbers and a pic to confirm they r LX arms not UC i crawled under the UC and took a pic of the lx arm sitting along side the uc one and u can see the difference sorry lx304 and rory they arnt want u r looking for
#21 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 29 January 2009 - 09:48 PM
Youre right Rorym . Looks like the UC arm only needs bending to to make it close to an A9x one by that picture.
