ADJUSTABLE REAR UPPER REAR ARMS FOR LH-LX
#1 _LH SLR 3300_
Posted 12 April 2009 - 10:59 AM
I saw on evilbay recently a pair of adjustable rear upper control arms for LH-LX Toranas. I didn't think much of it until I raced my LH at the forum meet last wendsday at WSID. Apart from traction issues due my choice of tyre, the car has some issues with the diff & rear suspension. Maybe the wrong pinion angle of the diff or such could be part of the problem. Anyhow I would be interested in any feedback regarding these parts & possibly a supplier I can purchase them off.
Cheers Matt
#2 _SableMet7/73_
Posted 12 April 2009 - 11:30 AM
Bought the McDonald Bros Racing upper arms not long ago
for my HQ & cost $315.00 + freight to WA ($25). My stock Q
arms look identical to the 1s in my LJ but dunno about LH/X.
Had a look at the Whiteline arms but prefered the look of the
McDonalds & found them really easy to deal with also found it
cheaper to buy direct.
Have a look at both McDonalds & Whiteline websites as theres pics
to check out & theres also a few threads on Adjustable Arms so
maybe do a search.
Cheers Jono
Posted 12 April 2009 - 12:16 PM
#4 _LH SLR 3300_
Posted 12 April 2009 - 01:14 PM
#5 _SableMet7/73_
Posted 12 April 2009 - 02:34 PM
Gday Andy, how come the McDonald arms require a
mod on the Torana?
#6 _CHOPPER_
Posted 12 April 2009 - 04:41 PM
Posted 12 April 2009 - 05:51 PM
There is another thread, same subject, with pics around here somewhere
#9 _Squarepants_
Posted 13 April 2009 - 09:28 AM
The only thing that I can see that may need modifying is the bracket that mounts to the diff sometimes hits the diff mount when the suspension is fully compressed. My car is fairly low though and this probably wouldn't be a problem with standard height suspension.
All they need is a little notching around the bottom of the rear mount, I'll get around to it one day soon, not a major issue.
Posted 13 April 2009 - 11:29 AM
You are correct the top diff mount requires notching so the arm can swing through full travel. The arm locks when the diff is about an inch off the bump stops. This is extremely dangerous even with standard height suspension and should be corrected before the car is driven.
There is a considerable amount of grinding required. You must ensure that the arms to not bind when the diff is jacked as high as it will go with the bump stops removed.
#11 _LH SLR 3300_
Posted 13 April 2009 - 12:25 PM
Posted 13 April 2009 - 10:27 PM
#13 _Squarepants_
Posted 16 May 2009 - 11:19 AM
This is what I've done so far...
I've dummy fitted them up and it looks like it should give enough clearance for full travel up to the bumpstops, but without dropping the springs out I can't be 100% sure.
#14 _rorym_
Posted 16 May 2009 - 06:17 PM
Many diff conversions use boxed HQ trailing arms for the upper diff mount. The McDonald Bros arms are designed to be used with the boxed HQ trailing arm upper diff mounts.
^^^ Correct, my diff guy fits HQ mounts for this reason.
#15 _SS Hatchback_
Posted 17 May 2009 - 12:45 AM
Ill be keen to see how you go with this , I have a set just waiting to go in and mine is pretty low so im sure i will definately have issues. It looks like you have ground as much as you can hopefully they will be ok.Has anyone modified their McDonald Bros arms before? I started doing mine today, just not sure how much I need to remove.
I just returned a set of whiteline ones because even with them fully retracted they were still too long by heaps. Maybe they sent the wrong ones im not sure but the mcdonald bros ones seem to look a little more sturdy .
#16 _Squarepants_
Posted 17 May 2009 - 12:55 AM
Anyone who has successfully done this before is welcome to chime in now...
Posted 17 May 2009 - 03:33 PM
Or you could cut a relief into the diffhousing brackets for clearance and weld in an infill section.
I wouldnt want to remove anymore material than you already have as you could make the arm weaker than a standard one.
#19 _SS Hatchback_
Posted 17 May 2009 - 05:30 PM
#20 _Squarepants_
Posted 17 May 2009 - 07:00 PM
Excelent ideas Wot!Ive never done it,but I'd be tempted to cut the channel sections off the arms where they attach to the diff and make and reweld on new channel sections a little deeper so that there is clearance without grinding material from the arm.
They're back in now so I guess I'll go and drive over a few speed bumps and check to see if they're still hitting.
I wish McDonald Bros mentioned this when I bought them, they sell them as a direct replacement for the standard arms which is misleading IMO. I might give them a ring if I have any more drama and see what they have to say for themselves.
#21 _SS Hatchback_
Posted 18 May 2009 - 06:36 PM
Excelent ideas Wot!
Cool awaiting progress. Good luck
#22
Posted 20 December 2010 - 01:23 PM
#23 _sshatch355_
Posted 20 December 2010 - 08:05 PM
http://www.rodtech.com.au/
