Has anyone fitted a Davis Craig electric water pump to a holden 6, I've just come across a problem, that when you go to fit the v belt from the balancer to the alternator the v belt is going to hit the timing marker that's on the timing case due to not enough angle.
Page 1 of 1
Electric water pump on holden 6
Posted 30 July 2010 - 06:50 PM
Can you possibly mount an idler pulley some where so belt follows close to original path not knowing what there is where old pump was makes it hard to answer but seems like the easiest solution to me
Page 1 of 1
Sign In
Register
Help
MultiQuote
