Hiding heater fan wiring
11 replies to this topic
#1 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 04 September 2010 - 08:56 PM
Thought i might throw this up here, a bit of a guide to hiding the wiring for the heater/demister fan in the engine bay.
This works with the lucas fan, if you don't have one you can find them in some of the HQ-WB's
The one on the left is the one you want.
Attached File  IMGP0977_resize.JPG   145.6K   12 downloads
Remove the 3 screws holding the fan to the plastic ducting, then undo the nut holding on the fan and undo the 2 bolts from the back of the fan which will allow the fan to be pulled apart.
Now cut the orange wire near the plug and cut the yellow resistance wire in the motor near the brush holder. Should look something like this.
Attached File  IMGP0975_resize.JPG   155.77K   10 downloads
The mounting plate now needs the spot where the wire came through filled. Just weld in a small peice of 1.2 milds steel sheet, and a quick sand.
Attached File  IMGP0976_resize.JPG   141.13K   7 downloads
Attached File  IMGP0978_resize.JPG   125.26K   6 downloads
Now weld on a small washer or something to hold the wiring down away from the fan.
Attached File  IMGP0984_resize.JPG   76.84K   6 downloads
While the fan is out of the plastic duct re-fit it to the car and mark the inside on the fire wall and pick a spot to drill a hole for the wiring to go through. ( Drill a 12.5mm hole for a wiring gromet)
Attached File  IMGP0987_resize.JPG   104.97K   6 downloads
A little trick to hold the thrust washer on when putting the armature back in is to hold it on with a bit of string, then pull the sting out when it's in.
Attached File  IMGP0980_resize.JPG   116.9K   6 downloads
Now extend the wiring and start putting it back together, put the back of the motor onto the mounting plate then fit the brush holders then the front motor cover.
Attached File  IMGP0982_resize.JPG   138.86K   6 downloads
Attached File  IMGP0985_resize.JPG   142.36K   7 downloads
Once the fan is remounted and the wiring is run through the fire wall, rewire the resistance wire and the orange power to the plug and reconnect the earth.
Hope this helps everyone...
Edited by turbo76lx, 22 October 2017 - 08:44 AM.
#2 barny_lx
barny_lx
  • 601 posts
Posted 04 September 2010 - 10:45 PM
nice little mod mate... i think Marc ( Green Machine) has done thesame thing on his hatch......very simple but looks great...
#3 _dirtbag_
_dirtbag_
Posted 05 September 2010 - 06:26 AM
Yeah, I love that mod. I copied the idea too : )
#4 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 05 September 2010 - 08:14 AM
I've seen it done on a few cars too and thought it would be good to have a how to do. I should say the yellow resistance wire is what give you the fan low speed
and if you use a fan from a HQ-WB they have only 1 wire coming out of the motor and the earth is attached to 1 of the 3 mounting screws, so need a little more work.
#5 76lxhatch
  • 7,220 posts
Posted 05 September 2010 - 08:20 AM
I normally just glue the wiring to the mounting plate, that washer idea is a lot better!
#6 _Taz2_
_Taz2_
Posted 11 September 2010 - 07:47 PM
Great tip and brilliant photos.
THANKS!!!
#7 TerrA LX
Posted 11 September 2010 - 08:09 PM
Excallent
#8 _greenmachine215_
_greenmachine215_
Posted 23 September 2010 - 04:14 AM
I done this mod to my hatch after i had everything chromed.
LOL I didnt think of goin the washer idea, i used tape that unfortunately come loose now the wires rattle against the fan sometimes,
Also have drama's running the fan on SUPER SLOW (1st speed) the yellow resistance wire glows red hot and starts to melt the silicone insulation. But once i switch it up to SLOW (2nd speed) its fine.
Not sure what the go is there, In saying that If i feel the need to let the breeze whisk through my hair i usually put the window down.
ANOTHER Mod i also done at the same time was...
Back wired the wiper motor and filled in the old plug hole with bog and sprayed it black, That works a treat aswell
similar process to the fan motor, takes about the same amount of time but ends up with a trick finish
#9 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
  • Car:UC Torana Hatch
Posted 18 April 2015 - 08:39 PM
Don't suppose you have any pics of this wiper motor mod?
#10 lh 4dr
lh 4dr
  • 54 posts
  • Name:dave
  • Car:lh sedan
Posted 04 February 2016 - 07:04 PM
What is the reason for cutting out the resistance wire. The original wiring uses it?
#11 76lxhatch
  • 7,220 posts
Posted 05 February 2016 - 05:49 AM
He didn't, it was cut as close to the motor as possible so that the original length was retained, then re-joined to the new extended wiring
#12 turbo76lx
turbo76lx
  • 656 posts
  • Name:Glen
  • Car:LX
Posted 22 October 2017 - 08:51 AM
Photos re-added to the thread.
This is how it will look when done.
Attached File  IMGP2788_resize.JPG   143.06K   14 downloads
