170+hp 202 red questions.
#1 _LJAY_
Posted 28 October 2006 - 08:30 PM
I've only just joined up, and already here to pick at your brains lol.
I have only a few weeks ago picked up and LJ 4 door 202 4 speed. I've put a lot of thought into the way I'm going to tackle the engine rebuild. Originally I wanted to slot an 8 into the LJ but decided on keeping the 202 and giving her a good kick in the guts.
Being as its my first holden 6 (coming off a few Ford 8's) I'm looking for some direction, as to how to pull anywhere between 170-200HP at the feet. It's not going to be a daily driver but more of a weekender and also to hit the strip occasinally.
I want to steer clear of the efi and keep with the triple su's I have at the moment. Unless of course you have a better idea? The block is standard bore at the moment, so should I leave it as is or increase the bore say 40-60thou? What piston's have you found to be good? Rod's, Cam, Ignition, Coil, Fuel Pump, Head, Rockers? Anything you belive will lead me in the right direction.
I've also had a look at the CRS charger kits, but unsure of the power figures and the stress on the engine. Even though I said before that I wish to retain the triples, I would like to know how they stack up againts a hot 6.
Thanks heaps ppl all replys will be much appreciated.....
Jay....
#2 _chevy_253_torana_
Posted 28 October 2006 - 08:44 PM
im currently doing a blue 202 with vk efi and a small toyota supercharger
#3 _DocDamage_
Posted 28 October 2006 - 09:05 PM
Posted 28 October 2006 - 09:06 PM
Yella Terra Head
triples
Cam of your choice ( do a cam sheet from whatever manufacturer you want)
extractors and a 2 inch exhaust
compression between 9.5 and 10 to 1
Blue motor HEI distributor
#5 _LJAY_
Posted 28 October 2006 - 10:12 PM
Also how do these motors hold up with a dose of giggle gas?
#6 _DocDamage_
Posted 28 October 2006 - 10:22 PM
#7 _LJAY_
Posted 29 October 2006 - 09:16 AM
What aboout valves and valve gear?
I noticed that the blue HEI Dizzy was mentioned aswell, I have a billet procomp dizzy and a bosch coil that came with the car but aren't installed yet would they be better than the blue HEI?
Thanks to everyone that has leant me there ear MUCH APPRECIATED guys...
Jay.....
Posted 29 October 2006 - 09:43 AM
Posted 29 October 2006 - 10:33 AM
YT head @10:1 comp
starfire rods
ACL pistons (HQ racing)
a cam somewhere around XU-1 specs
extractors and a 2 or 2 1/4 system
for the fuel pump you have a few options:
Blue motor mechanical fuel pump
Electric (Holley ect.)
or a SBC mechanical pump, they bolt straight up.
for the dizzy, throw the Procomp one as far as you can, they are useless. get a blue HEI dizzy, they go pretty cheap anyway.
this is basically the setup that is going into dads LC, except I am trying to talk him out of using the triple CD150s he picked up yesterday and to use the 1.75 SU's sitting in the shed
Posted 29 October 2006 - 11:02 AM
Edited by rodomo, 29 October 2006 - 11:07 AM.
#11 _Keithy's_UC_
Posted 30 October 2006 - 09:54 AM
I spent $4500 on a 179 (which is now 186cu) and ran a small holley to achieve 140rwhp. It runs starfire rods (from either a black 202 or as you mention - a starfire 4 [which i happen to have as of today]), hyperutectic pistons, ACL bearings, a worked standard head ($1200 worth of valves and springs, porting and grub screwing of studs) with roller rockers, and XU-1 cam and lightened flywheel. I've got 10:1 comp and run on 98octane fuel.
If you throw a bigger cam in and up the compression to maybe 10.5:1 with all that strengthened gear you should have no trouble at all.
But there's no power in a 2" exhaust (sorry FastEH), i had 130rwhp with a 2 1/4" and now have 140rwhp with a 2 1/2"... And you have more stroke than me with your 202, so i'd say with a similar build status to mine you'd see at least 170rwhp with just that and your triples. The bloke who dyno tuned my car said that either a 465 holley or a set of triple SU's (which i have sitting here) would see an easy 155rwhp... Did i mention mine is a street driven motor? It's got attitude, but not enough to make you want to take the back streets to avoid traffic lights...
Go the HEI dizzy off a blue 202, they are the ducks guts...
Keith
Posted 30 October 2006 - 10:57 AM
I haven't pushed my motor too hard just yet, still listening to things as I drive....but one aspect is the diff..... just how strong are they as standard.
And was there just one ratio in the UC 6's?
What would mine be...?
Edited by knoath, 30 October 2006 - 11:01 AM.
#13 _dave720gtr_
Posted 30 October 2006 - 11:14 AM
#14 _Aquarius - LC_
Posted 30 October 2006 - 12:00 PM
#15 _dave720gtr_
Posted 30 October 2006 - 12:37 PM
#16 _draglc_
Posted 30 October 2006 - 01:11 PM
202, big $ yt 186 head, roller rockers, big solid cam(512" lift), flat top pistons, triple 1.75 HIF sus, complete 5 spd conversion. mini high torque starter, you get the idea!
A1
#17 _@milco@_
Posted 30 October 2006 - 04:02 PM
mmm i grew up in moe and i have not heard many good things about them, but they have a new guy doing there engine's now and he seems to know what he is on about/doingmoe engines do a good donk price but good 180hp fly wheel with a 350 holley
street warror 3.3
#18 _LJAY_
Posted 30 October 2006 - 05:37 PM
By the way got my hands on a blue HEI today so thats a start I suppouse!!
Jay....
Posted 30 October 2006 - 08:35 PM
Nothing but reliability......
There's nothing quite like a Holden.......part.
