LC,LJ
#1 _tuffgong_
Posted 14 November 2006 - 06:39 AM
#2 _smelvin_
Posted 14 November 2006 - 07:55 AM
#3 _smiley_
Posted 14 November 2006 - 09:00 AM
Posted 14 November 2006 - 02:34 PM
#5 _smiley_
Posted 14 November 2006 - 02:48 PM
#6 _tuffgong_
Posted 14 November 2006 - 03:42 PM
#7 _finer70_
Posted 14 November 2006 - 04:20 PM
LC heater assemblies are fixed to the base plate with clips.
LJ heater assemblies have bolts with the nots exposed to the engine bay.
#8 _smelvin_
Posted 14 November 2006 - 05:18 PM
After reading other peoples responses I wonder if the boxes are the same but some of the bits in/on/around the box are different.I think they are the same. If it's whats called the ''heater case'' in the parts manuals they have the same part numbers. In saying this the ''heater and demister assemblies'' don't share a part number.
#9 _smiley_
Posted 14 November 2006 - 06:52 PM
Hang on there is more to it than that.
All of the boxes have the clips across the front of them and then bolts around the back ,the bolts you speak of are around the fan assembly side of the heater assembly.By all my books I count 7 clips across the front of the boxes...LC/LJ
#10 _munro_
Posted 14 November 2006 - 06:55 PM
1 is fan forced (identical to Lj)
1 isnt . The second one looks like the vent only casing but with the heater hoses entering from each side and there brilliant for v8 conversions.
the third if a vent only (no heater). i own all 3.
cheers tom
#11 _doublin gtr_
Posted 17 November 2006 - 06:35 AM
small rectangle but on the lc were this is it says holden.
smiley mine is early 72 and has the screw not a clip
#12 _73LJWhiteSL_
Posted 18 November 2006 - 10:35 AM
Dr Terry?
Steve
#13 _192cubes_
Posted 19 November 2006 - 01:33 PM
I have the heater box from a 72 and it has the nut and bolt. The car definately had white blinkers. IIRC that id's it as a 72?
If not my apologies
Dave
#14 _finer70_
Posted 19 November 2006 - 02:49 PM
The clip business explained above is only part of the difference.
1 - I was talking about the fan forced heater assembly.
2 - From what I have seen the LJ heater assembly has vertical stud bolts with exposed nuts around the heater casing to the steel base at the wiper motor end of the heater. The LC's seem to only use clips all around the fiberglass casing to hold it together with the flat steel base of the case.
Posted 27 May 2007 - 09:47 AM
Can anybody tell me the name of the plate that bolts to the firewall that the heater box feeds into ?
Also it would be very handy for some pics in this tread highlighting the difference between the models.
What we need is Bazza with his magic marker pen!!! Bazza where are you ???
L
Posted 27 May 2007 - 10:22 AM
Posted 27 January 2018 - 12:15 PM
g'day all
i know this is an old thread
i have a 8/73 4 door asa parts car
so will the heater bx and attaching plates fit a 71 lc
cheers bat
Posted 27 January 2018 - 12:25 PM
g'day all
cheers bat
Yes, however the control cable attachment on the top of the heater box is different between LC & LJ. LC cable uses a clip onto the attaching plate and the LJ cable has a moulded plastic lug that bolts to the attaching plate.
Posted 27 January 2018 - 01:14 PM
bobs you uncle unless your going original..
Edit: actually cable mightn fit as the lug
on cable has to pass through a smaller hole
on heater box shelf than what lj have.you
could drill hole fractionally bigger to allow
it to pass andthen seal it up if you like or
just get the plate for box to suit cable..
Edited by madtoranajzedded, 27 January 2018 - 01:35 PM.
Posted 28 January 2018 - 07:44 PM
One other difference, very minor and easy to replicate. LC XU1s only had an extra hole in them.
