TT Lexus V8 into LJ
#26
Posted 20 November 2006 - 09:10 AM
#27 _LHoon_
Posted 20 November 2006 - 10:58 AM
I was just thinking that the radiator would only take up 2/3rds of the fuel tank hole, and the other 1/3 would be used for sucking fresh air into the boot. I could even make up some tubing to direct the air through the radiator somehow. But that might not be needed becaue the boot is sealed.
Fans (positioned underneath the radiator) would suck air through the radiator, drawing the 'fresh' air from the boot and releasing the hot air underneath the car.
The radiator is only really needed when we want to run the car on premium unleaded. This will mostly be during cruising at car events or for testing. When run on methanol (at the drags etc), the engine won't really get very hot.
#28
Posted 20 November 2006 - 02:09 PM
#29 _IPRALC4Door_
Posted 20 November 2006 - 02:21 PM
#30 _LX406_
Posted 20 November 2006 - 02:50 PM
#31
Posted 20 November 2006 - 03:24 PM
you would get good airflow and keep most of the heat out of the boot
#32 _LHoon_
Posted 20 November 2006 - 03:43 PM
LX406 - The boot will be full of fresh cool air, which is drawn in directly into the boot through a port hole. This cool air is then drawn through the radiator (by fans)to the outside of the car. There would be a constant flow of cool ambient air into the boot. I don't expect the it to get hot at all in there.
We'll be running fairly low on space in the engine bay, but there may still be space for a small tank. We haven't ruled it out as an option.
IPRALC - yes we have thought about a dry sump, but didn't think it was necessary.
#33 _LHoon_
Posted 20 November 2006 - 04:25 PM
The only thing I'm a little concerned about is that the air might be continually recirculated around and around. It would be ok when the car is moving, but when stationary the hot air may just hand around under the rear of the car. It might not be that bad. What do you think?
#34
Posted 20 November 2006 - 05:54 PM
#35 _LHoon_
Posted 20 November 2006 - 09:27 PM
On a side note...
We bought a hi-stall convertor for the powerglide. Although we don't actually have a powerglide yet, but we'll get one eventually. We bought this convertor off ebay. Its a Dominator 5500rpm convertor!! Awesome!!!
The guy I bought it off said the stall speed has been designed for a small block chev, so I expect the flash stall to only be around 4500rpm with a little ol' 4.0L engine... but the boost will help with torque to push up that stall speed a bit. This convertor will be helpful off the line when we get new cams.
Next on the shopping list is a big throttle body.
#36 _LHoon_
Posted 23 November 2006 - 03:50 PM
I doubt that this will restrict power. Check it out, its massive!
And here it is next to an XF throttle body. The XF one is what VL turbo guys usually use as an �upgrade�.
#37 _MRNOS_
Posted 23 November 2006 - 03:55 PM
#38 _LHoon_
#39 _MRNOS_
Posted 23 November 2006 - 04:15 PM
#40
Posted 23 November 2006 - 06:15 PM
'Vat is one masiv masiv.'
Bloody hell. Say goodbye to your pet kitten, that'll be Lexus Lunch!
RIM
#41 _LHoon_
Posted 25 November 2006 - 03:07 PM
I've now got a 9 inch housing and axles for the LJ. Its torana stud pattern and standard LC/LJ length. I might consider shortening it a couple of inches later on. I will probably also convert it to HQ stud pattern eventually.
I'll be keeping an eye out for cheap diff centres now!
#42 _munro_
Posted 25 November 2006 - 10:01 PM
lhoon i recon if your going to shorten the 9" and change stud patternaswell as look for a centre you'd be better off buying another 9" pay for it to be cut down ect then sell the one you haveI'm slowly collecting bits for this car, but its an expensive exercise!
you'll save atleast a couple hundred dollars
cheers tom
#43 _MRNOS_
Posted 25 November 2006 - 10:21 PM
#44 _postal_dood_
Posted 26 November 2006 - 07:42 AM
but still, comming along nicely.
#45 _LHoon_
Posted 26 November 2006 - 10:10 AM
MRNOS - this project is coming along fairly quickly, but we have been working on it for a few months. It seems quicker because I've posted all these photos up so quickly!
Muro - Yep I've been thinking the same thing myself. I may or may not use this diff. We'll see. I could also use it for my LC, and get rid of the borg warner.
#46 _LHoon_
Posted 30 November 2006 - 08:57 PM
Finished welding on the top tank of the intercooler, and drilled a 4 inch hole for the air outlet to match the huge throttle body we've got.
You'll also notice that we chopped the top off the old intake manifold plenum. We're re-designing it so that it fits under the bonnet of the LJ.
#47
Posted 30 November 2006 - 11:23 PM
Thanks for sharing the pics, very impressive engineering effort...
I think a goal for me next year is to do some welding courses, and learn how to use a TIG...
cheers,
Sam
#48 _LHoon_
Posted 01 December 2006 - 05:16 PM
We've now fabricated a new plenum chamber!! Unfortunately the old trumpets/bellmouths are a bit tall, so we're going to have to remake them. But the exterior is made, and you can now see how the throttle body will fit, and plumb straight into the intercooler. It all fits under the bonnet, and it should look pretty sweet!!
#49 _brett_32i_
Posted 02 December 2006 - 04:55 PM
that guard looks hot!!! should do the whole car and throw some clear over it..
#50 _postal_dood_
Posted 02 December 2006 - 05:51 PM
this thing is going to be frigin insane. TT v8 under the bonnet of a torana with nothing showing other than the intercooler. hahaha smash the shit outa any ricer that thinks there cool. Top effort Lhoon, cant wait till tis ready
