hi guys, does the intermittant wiper control switch on the uc dash need a control box to operate or can it just be intergrated into the older lx type loom.
UC intermittant wiper
, Dec 23 2006 08:41 PM
4 replies to this topic
Posted 23 December 2006 - 08:41 PM
#2 _devilsadvocate_
Posted 23 December 2006 - 09:45 PM
It comes with a bosch module.
Posted 23 December 2006 - 09:50 PM
thanx.
#4 _devilsadvocate_
Posted 23 December 2006 - 09:54 PM
To connect the the unit gets put in the low speed(i think) wire to the existing wiper motor(its the white wire on the UC), cut the wire and join each end to the two white wires of the control box. The yellow goes to the accessories.
Posted 02 January 2007 - 11:05 AM
The orientation of the white wires from the control box matters too. Cut the white wire from the original windscreen wiper switch (LH/LX as well as UC). The long wire needs to go to the wiper motor end of the cut white wire, and the short one goes to the switch end.
If you use the same type of connectors as the intermittent control unit on the cut white wire, you can also easily bypass the intermittent control unit if it fails, or if you are testing it.
