Dan's LS1 LX SL
207 replies to this topic
#176 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 27 October 2019 - 01:26 AM
Looks good.
What seat belts did you use ?
The retractable rears are HZ i believe
#177 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 28 October 2019 - 09:44 AM
Is that the original coconut fibre on the floor Dan?
#178 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 28 October 2019 - 02:50 PM
Yeah
#179 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 03 November 2019 - 11:29 AM
Still waiting for the dash from AISAT
Also being 5x120 pattern all around my wheel track was too skinny for engineering (you are only allowed to go wider) so the billets have been offset modified to suit
Interior mostly back in (first time it's had carpet in over 10 years!). The left hand side doors will need painting when the engineering circus is over hence the different trims
#180 CI 0308
CI 0308
  • 736 posts
  • Car:77 LX SS, VX SS
Posted 03 November 2019 - 12:12 PM
Fancy being pinged at Engineering for going too "Skinny" It used to be for being to "fat" when I was a lad.
#181 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 03 November 2019 - 01:02 PM
Yeah it is pretty strange
It is a mixture of the R31 diff swap and Hoppers on the front
Otherwise surely anyone that does the usual HQ stud swap doesn't have track problems
I guess no one worried about it unless it is being engineered
#182 Bigfella237
  • 4,371 posts
Posted 03 November 2019 - 01:09 PM
If I remember correctly this diff came out of a VL Commodore and got shortened for the Torana?
Commodore wheels will always be the correct offset for a Commodore diff, no matter whether it's been shortened or lengthened. I'm guessing your engineer must be using the original Torana track measurements, which is wrong, he or she needs to re-read the NCOP!
From NCOP11-Section-LS-Tyres-Rims-Suspension-Steering-Wheel-Track, Page 47:
NCOP11-Secton-LS-Tyres-Rims-Suspension-S
It's based on "the axle manufacturer's original track dimension", not the fitted vehicle's original specs.
The whole idea is to maintain the axle manufacturer's intended load across the wheel bearing(s) and axle assembly. Trying to achieve the Torana track figure would be like bolting really wide offset wheels on a Commodore, which would/should never pass engineering on a diff in a Commodore, so why should it pass on a Commodore diff in anything else.
#183 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 03 November 2019 - 02:13 PM
It is a R31 diff with custom axles and i got in on a group buy here for blank discs
Every engineer seams to be different i just want this all to end haha
#184 ls2lxhatch
  • 5,331 posts
Posted 04 November 2019 - 12:46 PM
The factory track cannot be reduced and can only be increased by a maximum of 25 mm. This allows you to reduce the factory rim offset by a maximum of 12.5 mm with the factory diff.
The final track of the vehicle fitted with a replacement diff has to comply with the above rules. The only thing that changes is the baseline rim offset which can only be increased by a maximum of 12.5 mm.
If you cannot achieve the required track with a replacement diff by increasing the donor rim offset by up to 12.5 mm then you must reduce the diff width.
From memory R31 diff is a similar width to the standard Torana diff so it will need a rim with a similar offset to the Torana rims. The Torana rims have an offset around +6 mm. The R31 factory offset is around +30
The steel rims on the car now appear to be Commodore rims which have an offset around +41 mm to +43 mm which will make the track too narrow. You should be able to achieve the required track by reducing the rim offset.
The only thing to watch out for is brake clearance with the reduced offset rims.
Edited by ls2lxhatch, 04 November 2019 - 12:55 PM.
#185 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 04 November 2019 - 03:06 PM
Thanks!
The track is on point now with the modified commodore steelies
I hope to get some hotwires for it when funds allow, for now i just want to go cruising with the family and put some k's on it so don't really care what rims it has
#186 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 27 November 2019 - 09:15 PM
Well there was major delays on the dash at AISAT. It certainly looks the part though!
The angle and daylight i took the pic makes the yellow look a bit light but i assure that it is not
It is a LH SLR Cluster, with VDO electronic speedo, electronic tacho, voltage reg mod, calibrated & all lights tested, new rares lense kit, lx slr decals from grafixunlimted
Will comment on it's operation after i drive the car myself
Hopefully engineer can get the swept volume, brake & noise test done next week that is all that will be left after the dyno!
It is sitting nice now the offset is correct, also swapped to VL Wagon shocks as the lovells weren't captive
Edited by DanWA, 27 November 2019 - 09:16 PM.
#187 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 28 November 2019 - 09:28 AM
Wow. That dash is awesome. You must be getting an itchy trigger finger. :)
#188 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 30 November 2019 - 08:14 PM
Another engineering box ticked
Car is now tuned and been signed off by engineer
#189 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 01 December 2019 - 09:26 AM
That Commodore has turbos bigger than my truck. And it only has one of them!!
Edited by Shiney005, 01 December 2019 - 09:26 AM.
#190 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 14 December 2019 - 06:13 PM
Well....................... I passed engineering on Friday!
Now to pass a pit inspection when DoT get their act together
#191 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 15 December 2019 - 09:43 AM
Do you have to go to a DOT inspection centre or can you just head down to Central Garage and get Sheppy to do the inspection?
#192 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 15 December 2019 - 10:39 AM
Just Sheppy, but have to wait for DoT to process the engineer's report first.
Being christmas time this might be a post new years thing, AISAT are not back until 2nd week of January to sort the dash out anyway.
#193 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 15 December 2019 - 12:25 PM
Darkan is sometimes "easier" than Collie to get a car passed.
#194 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 16 December 2019 - 07:25 PM
Had it weighed for rego today
1285kg with full tank
Not bad for Cammed LS1, T400 & Diff Conversion etc
#195 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 16 December 2019 - 10:39 PM
#196 Ice
  • 15,122 posts
Posted 16 December 2019 - 10:49 PM
Whats the steering like with the LS in it Dan ?
#197 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 16 December 2019 - 10:51 PM
Absolutely no need for power steering, steers better than my old 308 Kingswood that had power steering
#198 Ice
  • 15,122 posts
Posted 16 December 2019 - 10:54 PM
Awesome ✌️
#199 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 18 December 2019 - 11:48 AM
It is great to finally see it out and about Dan. Can't wait to see it drive past me on the street.
#200 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 18 December 2019 - 12:37 PM
Had a few looks and chats to/from the weighbridge
It's a little different from the normal fancy paint jobs and flares but i'm not into that flashy business anyway :)
