bloody cars
#1 _LX8VD69_
Posted 22 February 2007 - 09:43 PM
Posted 22 February 2007 - 09:49 PM
if water/WD40 has made it inside the dizzy you may have to pull it and turn it upside down to drain it.
i tend to use shopping bag to wrap things i don't want wet, especially in later stuff, they really don't like water.
EDIT; try house hold paper towel for the drying.
oh just realised it's a VL, water sits in the head between plugs 3 and 4 as well.
again paper towel tristed together will wick it out, or a compressor to blow it out.
you shouldn't need to pull the dizzy, just make sure it;'s dry, and never get the modulator wet (bit on dizzy).
Edited by ALX76, 22 February 2007 - 09:56 PM.
Posted 22 February 2007 - 09:52 PM
#4 _LX8VD69_
Posted 22 February 2007 - 09:56 PM
thanks guys keep them coming
adam
Posted 22 February 2007 - 09:59 PM
At least it is not the dreaded dying crank angle sensor problem.
#6 _TORANASS_
Posted 22 February 2007 - 10:01 PM
VLs are notorious for this, they get water stuck in the dizzy witch holds the crank angle sensor and it stuffs things bigtime. Your best bet is to blow it all with an air compressor and leave the bonnet up in the sun for a few hours.
John
Posted 22 February 2007 - 10:07 PM
i had one once that would rev to 3000rpm and then start to play up. the new (read reco) one i bought was worse, it was exchanged and all ok.
#8 _LX8VD69_
Posted 22 February 2007 - 10:08 PM
#9 _1QUICK LJ_
Posted 22 February 2007 - 10:17 PM
Posted 23 February 2007 - 02:14 AM
Edited by rodomo, 23 February 2007 - 02:16 AM.
Posted 23 February 2007 - 07:15 AM
My old VL Berlina I sold some two years ago was the quietest and most reliable car I had ever owned. Compared to my current VY Berlina the RB 30 straight six was so quiet you couldn't hear the car running and always returned me over 600ks per tank in the country.
Posted 23 February 2007 - 07:42 AM
Dan
