186 221 Crank Stroker
20 replies to this topic
#1 _boynuz_
_boynuz_
Posted 08 May 2007 - 09:15 PM
Has anyone got a 179 or 186 with the 221 crank, What carbie setup do you run and how reliable is it ?
#2 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 09 May 2007 - 12:18 AM
mine isn't running yet..but twin 425 impco gas mixers are planned.
reliability...plenty of people use them...cant be that bad.
#3 _Bomber Watson_
Posted 09 May 2007 - 08:29 PM
i dont think i'd ever put a welded ford crank into my motor, but suppose if you didnt want to make a lot of power it would be ok.
#4 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 09 May 2007 - 11:25 PM
They have been doing them for over 15 years that I know off...I still haven't seen one let go.
They do warrant the weld.
#5 dattoman
  • 16,471 posts
Posted 09 May 2007 - 11:30 PM
The 235 setup has been used for well over 20 years
I've never seen or heard of a failure
Theres a few other strokers here who will have an opinion
#6 _boynuz_
_boynuz_
Posted 10 May 2007 - 10:20 PM
I've also heard about a hemi 245 crank in a 202.
#7 _levis_
_levis_
Posted 10 May 2007 - 10:26 PM
ive heared of hemi rods being used in a stroker application but not the crank any more info?
#8 _boynuz_
_boynuz_
Posted 10 May 2007 - 11:27 PM
The place is called bryant engineering but can't find it on the web it makes a 202 into a 249.
#9 liswar2
liswar2
  • 1,483 posts
  • Name:Wazza
Posted 21 May 2020 - 01:06 PM
Dyno run this morning 9.30 am in Bunbury WA
130 HP at rear wheels
#10 liswar2
liswar2
  • 1,483 posts
  • Name:Wazza
Posted 21 May 2020 - 01:20 PM
186/221
M20
2.78 LSD
205/60/13s
95 Ron
Spark gap electronic re graphed dizzy 1.1mm
Video to follow when I can work that bit out
#11 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 21 May 2020 - 01:40 PM
Are you happy with that result?
What induction does it run?
#12 claysummers
claysummers
  • 3,333 posts
  • Name:Clay
Posted 21 May 2020 - 02:58 PM
I be more interested in torque figure
#13 purrlx
purrlx
  • 1,330 posts
  • Name:Danny
  • Car:LX hatch
Posted 21 May 2020 - 04:15 PM
I had one I got from prostroke back in the mid 90’s for a speedway car. Had heaps of torque, but running on methanol. Found if you reved it to hard it ate main bearings, would be happy at 6000 to 6500 max. Anything close to 7000 expect bearing damage. Eventually went back to a blue 202 crank and different engine.
#14 liswar2
liswar2
  • 1,483 posts
  • Name:Wazza
Posted 21 May 2020 - 04:22 PM
Torque figures are on the print out,
Running 73 Xu-1 triples with factory intake and 2 piece headers
Ben running this set up for 4 years now , just did a dyno run out of curiosity,
#15 claysummers
claysummers
  • 3,333 posts
  • Name:Clay
Posted 21 May 2020 - 07:10 PM
Nice and tractable Warren. You’ve got the right diff on there. Nice highway setup.
#16 liswar2
liswar2
  • 1,483 posts
  • Name:Wazza
Posted 21 May 2020 - 10:41 PM
Yep as we live in the country side down here in Busselton , it's always the highway or bust
Perth is 2.5 hrs away....
#17 _LXT333_
_LXT333_
Posted 21 May 2020 - 10:51 PM
Nice
My old boss used to swear by the 235 and a 12port head.
Said he used to run high 12s at surfers drags Back in the day.
LJ with a 4 speed.
Always said it didn’t want to rev just made heaps of torque.
#18 claysummers
claysummers
  • 3,333 posts
  • Name:Clay
Posted 22 May 2020 - 08:57 AM
Mate got some 235-60-13 recently. Took him a while.
#19 Dr Terry
Dr Terry
  • 3,276 posts
Posted 22 May 2020 - 08:58 PM
The 221 stroker crank Holden 6 has been around for over 40 years.
I purchased a Holden 6 back in the mid 80s that was out of an NA rail that used to run at Castlereagh drag in the mid-70s. It was run by the Moore brothers, it had heaps of torque but wasn't happy at consistent high revs. This probably could have been sorted with modern balancing techniques, but it was still a great drive in a street car.
There is no problem with properly modified or properly welded cranks, it's all down to how well the work was done.
Dr Terry
#20 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 24 May 2020 - 11:13 AM
I like the idea of stroker 6s in the right application. If you are planning on revving quite a bit and quite frequently, I dare say the shorter rod ratio from the stroker wouldn't help harmonics, hence if you can fit the longest rod you can and run custom pistons, so the rod ratio is closer to a stock 202, it'd be ok..
In short, build it right and it will be ok.. but a basic stroker crank in a holden 6 making big hp and high rpm worries me as to the effect of harmonics. Maybe in an suto and high stall itd be ok but in a manual I dare say you will be having trouble holding flywheels on as well as other inherent signs of harmonics.
#21 liswar2
liswar2
  • 1,483 posts
  • Name:Wazza
Posted 24 May 2020 - 03:44 PM
Good looking 221
