L 34 VERIFICATION
21 replies to this topic
#1 _hotwire1970_
_hotwire1970_
Posted 28 May 2007 - 12:29 PM
HOW CAN I VERIFY AN L34 ENGINE USING ONLY THE ENGINE NUMBER,WHO DO I TALK TO???
#2 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 28 May 2007 - 12:32 PM
Well first you would need to talk, INSTEAD OF SHOUTING.
You could post the engine number and casting marks up here, including the head numbers and marks, that would give you a good start.
Didn't just buy it off ebay did you ?
Welby
#3 _JBM_
_JBM_
Posted 28 May 2007 - 04:08 PM
The engine prefix should start with HZ...
There should be extra webs around the rear main seal similar to the later blocks.
The main bearings are grooved.
It should have a cast date around the time of L34 production which was July, August and September 1974.
The short motor part no was 9936518 and the block fitted with pistons was 9936519.
The head part number is 9936382.
The specs of these blocks and heads can be easily duplicated and surpassed using newer blocks and other new parts so fitting a genuine L34 engine to a non L34 just makes it harder for genuine cars to be restored.
James
#4 _hotwire1970_
_hotwire1970_
Posted 28 May 2007 - 04:48 PM
The engine in question came out of an LH that was plated as an L32.
It has the extra webbing reinforcement around the main bearing,but no "X" mark that I can see on the block. I did read however in A.M.C. magazine,that not all L34's had this mark.
When I removed it from It's dead shell and stripped it,it had inside; a crow cam,flat top ACL's,X rods and L34 diameter valves but no roller rockers or studs.
It also has grooved main bearings,but no windage tray.
The heads have a letter B cast into them aswell-what does this mean? (brock heads?)
The block number could not be found in any records, by anyone that I have talked to yet.
It is...WT352655...and as far as anyone can tell it has not been interfered with.
It checks out with the RTA and REVS as not being stolen.
I have had it for around three years,but have not yet got around to rebuilding it yet.
thankyou for your very quick reply's...hotwire1970.
#5 GML-31
Posted 28 May 2007 - 05:17 PM
you sure its not a VT prefix which would make it a VK black motor with B Cast heads
If it is WT that is a WB statesman block 1980 era
Edited by GML-31, 28 May 2007 - 05:21 PM.
#6 _hotwire1970_
_hotwire1970_
Posted 29 May 2007 - 11:28 AM
It is ndefinately WT prefix but it has the 'B' stamped on the heads.
Thanks heaps to all those who replied :spoton:
#7 _racyrabbit_
_racyrabbit_
Posted 29 May 2007 - 12:16 PM
Defineately not a L34 block , can be NZ as well ,a lot of the original motors blew up so realy there shouldnt be as many HZ blocks around ,and i think they were all cast in july but could be wrong just going on mine and others i have looked at , A lot of people claim to have L34 motors i have been around to look at them and none of them were , Trex
#8 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 29 May 2007 - 07:15 PM
sounds like what you have there is a Brock WB Magnum engine
#9 _pallbag_
_pallbag_
Posted 14 July 2007 - 11:46 PM
Whereabouts is the "B" cast on these heads ?
Would luv to see a piccie of the B cast please ...
#10 _big_als_army_
_big_als_army_
Posted 15 July 2007 - 07:15 PM
The WT prefix 308 is listed for the WB Commercial from what I've found.
#11 _Mondie_
_Mondie_
Posted 15 July 2007 - 08:36 PM
Here you go Mr Bag. Thanks to who ever originally posted the pic :D
#12 _pallbag_
_pallbag_
Posted 15 July 2007 - 08:39 PM
Gee the "B" really looks dodgie doesnt it ? Thanks Mondie
Edited by pallbag, 15 July 2007 - 08:39 PM.
#13 _2FLYSLR_
_2FLYSLR_
Posted 26 September 2019 - 07:36 AM
The B is drawn in to the mould it was never perfect but definitely not welded onto the head which I have seen people replicate
#14 RedTaxi
RedTaxi
  • 61 posts
  • Name:Glen
  • Car:LX hatch
Posted 26 September 2019 - 12:40 PM
Back from the dead after 12 years!
#15 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 26 September 2019 - 07:15 PM
The B was done the same way as the X on the side of early super duper flux capacitor titanium blocks.  There are later blocks with an X stamped into the mould, but these are usually Turbo bolt pattern for commercial applications.
Edited by Shiney005, 26 September 2019 - 07:15 PM.
#16 yel327
  • 13,081 posts
Posted 26 September 2019 - 07:49 PM
^^Source Laurie? Not something I have ever seen in the flesh or in literature. I’ve seen X’s scratched into the green sand on trial ADR27A V8 heads used in some HJ a few months prior to 6/76 but never on blocks. Do you mean the early XT5 blocks in late 70’s Bedford?
#17 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 07 October 2019 - 03:46 PM
Sorry Byron, I must have missed this somehow.  Info came from Smitty over at Aussie V8s who worked in the foundry. I have heard that the Bedford motors have them, but they would be classed as a commercial motor, the same as the engines bought new from Holden for the N.S.W. Railways scarifying machines and whoever was building cement agitators back then. I have seen a QR block with one, but the one pictured below is December 1976 308, which I would have thought would be a bit late for Bedford?  (This is only people talking though. No proof.)
Attached File  Block. Small X. Dec 1976 Turbo block.JPG   43.55K   12 downloads
Edited by Shiney005, 07 October 2019 - 03:48 PM.
#18 piquet
piquet
  • 856 posts
Posted 11 October 2019 - 07:25 PM
I had a set of B cast cylinder heads for my L34. I bought them at a garage sale of the HDT when they were in North Melbourne.
They were big valve heads similar to L34 but were fitted to the VB/VC HDT Brock Commodores.
They were a pollution head so my original L34 inlet manifold would not fit and required finding the correct inlet manifold, which I did by going back to the HDT.
#19 yel327
  • 13,081 posts
Posted 11 October 2019 - 07:59 PM
Too early for Bedford. 4.2 and 5.0L weren’t fitted to Bedford until much later, like late 1978 into 1979 to replace Chevrolet 250 and 292 when they no longer complied with ADR’s (350 replaced 292 in C20/30 about the same time). These low comp 4.2 and 5.0L Bedford were the first XT5 V8’s, with the blue motor heads, intake, HEI dizzy etc.
#20 yel327
  • 13,081 posts
Posted 11 October 2019 - 08:06 PM
Not VB, only some VC-VK HDT engines, and also fitted to 1000’s of V5H manual Commodores for GroupA homologation. These were as you say similar to L34 engines, just had a bigger cam than L34 but lower compression.
#21 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 12 October 2019 - 10:43 AM
I didn't realise just how long the TK Bedford was around for. 27 years is a long time for one model.
#22 Rockoz
Rockoz
  • 3,965 posts
  • Name:Rob
Posted 12 October 2019 - 09:38 PM
My RFS Brigade had a 308 powered Bedford $wd.
From memory it was a 1980 model.
Other council areas with a bit more coin swapped the 308s for Isuzu diesels,
They were a tough truck.
Rob
