LJ Qtr Vent Windows
Posted 26 June 2007 - 10:16 AM
My locks on my qtr vent windows are loose-ish and leak a bit when its raining. What is the best method for tightening them up??
Also i am thinking of maing up some anti theft boxes for them too, the Nasco ones are too expensive for me, is there a cheaper alternative???
Cheers,
mick
#2 _Flamenco_
Posted 26 June 2007 - 11:36 AM
Posted 26 June 2007 - 12:22 PM
Posted 26 June 2007 - 12:53 PM
Flamenco, I will try to remove them on the weekend for a closer inspection.
keep the ideas coming guys and gals!!
Posted 26 June 2007 - 12:54 PM
#6 _Flamenco_
Posted 26 June 2007 - 12:59 PM
Posted 11 February 2013 - 12:25 AM
I'm thinking heat-gun, or thinners?
Maybe both at once for a real explosion.
Posted 11 February 2013 - 12:38 AM
Can anyone advise on how you get these fitting off when they're glued? I tried tapping one and the glass exploded into a zillion pieces.
Never tried this myself cause the glue had already let go on mine but it's just a thought.
Try some acetone (nail polish remover). Pour it into the annular space between the fitting and the glass and let it soak in. You may need to top it up now and again.
Dave.
Edited by S pack, 11 February 2013 - 12:39 AM.
#9 _LC870_
Posted 11 February 2013 - 08:39 AM
Posted 11 February 2013 - 11:35 AM
tell you what loctite freeze & release
spray is brilliant for release tight
things use heat gun spray this in leave
for 2 minutes to work & pull out very
handy when removing a stuck spigot bush.
All these ideas are worth trying appart
from the explosion allthough it does
sound cool let us know oh & the fibre
things are called fibre washers cheap &
esential & work a treat on heaps on
heaps of things ie absorb vibration ect.
Posted 11 February 2013 - 11:54 PM
IMG_2174.jpg 50.07K 10 downloads
IMG_2175.jpg 41.13K 6 downloads
To remove the chrome screws that clamp the glass i used an impact driver with great success. After the acetone and crc routine.
Thanks for your help.
Marty
