Rubber spacer under rear springs
#1 _salaszar_
Posted 15 July 2007 - 06:04 PM
#2 _trna76hb_
Posted 16 July 2007 - 01:38 PM
Yes these are standard fitment.
Maybe put a wanted in the wanted section, someonre will have one laynig around
ian
Posted 16 July 2007 - 02:17 PM
Posted 17 July 2007 - 07:09 PM
Posted 17 July 2007 - 08:53 PM
SuperPro
Noltec
Nolathane
Posted 17 July 2007 - 11:46 PM
I have a pair of each size here if you need the part numbers but it is a bit cold to go outside to the shed (not as cold as the guys down south though looking at the news:) ) - I have posted the numbers once before about 6 months ago.
I bought a new set of rubber ones from GMH about 10 years ago but I don't think they do them anymore - you could try rare spares and see if they list HQ ones if you don't like polyurethane.
M@
Posted 18 July 2007 - 01:29 AM
Thanks for the info.
SuperPro
http://www.fulcrumsu....au/fulcrumCat/
SPF0210-6K Rear Spring Insulator Bushing. Raises 2mm
SPF0210-8K Rear Spring Insulator Bushing view. Raises 4mm
SPF0210-12K Rear Spring Insulator Bushing view. Raises 8mm
SPF0210-19K Rear Spring Insulator Bushing view. Raises 15mm
Rare Spares
https://rsp-secure.c...number=A1713-6U
https://rsp-secure.c...number=A1713-8U
https://rsp-secure.c...umber=A1713-12U
https://rsp-secure.c...umber=A1713-19U
Noltec
http://www.noltecsus...earch by Model#
Nolathane.
http://www.redranger.com.au
47045 (+8mm)
47295 (+12mm)
Edited by ls2lxhatch, 18 July 2007 - 01:35 AM.
#8 _big chris_
Posted 05 March 2010 - 04:25 PM
rang Fulcrum,
they are getting me a pair of SPF0210-6K Rear Spring Insulator Bushing. Raises 2mm,
will see them on monday and see if they fit,
as we need a pair for the rear of the LX Hatch
Chris.
Edited by big chris, 05 March 2010 - 04:29 PM.
Posted 05 March 2010 - 04:40 PM
#10 _Squarepants_
Posted 05 March 2010 - 07:41 PM
As far as I have found out the super pro ones are just spacers, not replacement items, they are not spigoted to fit inside the top of the spring. They are designed to be used with the original insulators.
I haven't checked those links yet but I will do now as I'm after a set that will raise the back of my car up a bit.
Posted 05 March 2010 - 08:41 PM
They were listed as for an HQ.
The top inside edge was square where the saddle in the car is rounded, this required about 10 min with a sanding disc each side to get them to sit flush.
That aside they work well.
#12 _big chris_
Posted 10 March 2010 - 06:55 PM
We got the items from Fulcrum on monday afternoon,
and will be inserting them tomorow,
with the re bushed trailing arms and rebushed diff.
We got the old rubber insolator from a rusted out wrecked LX at Kellys,
so have a picture of the old ones that we did not have,
and the replacement HQ - WB one from Fulcrum.
The new one is about 3mm or 4mm thinner than the original,
but they are made in thicker ones than this one,
this is the 6mm, they are avavilable in 8mm and 12mm.
The listing from Fulcrum
Part Number: SPF0210-6K
Location Description: Spring Insulator Bushing
Important Instructions: Raises vehicle approximately 2mm
Number of Kits Required Per Vehicle: 2
Single Kit Contents: 1 Bushings
Suspension Location Applied To: Rear
Edited by big chris, 10 March 2010 - 06:57 PM.
Posted 10 March 2010 - 07:32 PM
Posted 10 March 2010 - 08:33 PM
#15 _glenn l_
Posted 10 April 2010 - 02:11 PM
glenn.
