XU1 Fan blade
#1 _purpleLC_
Posted 16 October 2007 - 10:42 PM
old bits I had lying around from my old XU1 days.
Not sure if it is Bathurst XU1 fan blade or not.
Did they come off a particular year model?
Cheers Louie
#2 _73LJWhiteSL_
Posted 16 October 2007 - 10:49 PM
Steve
#3 _Mondie_
Posted 16 October 2007 - 10:55 PM
Posted 16 October 2007 - 10:57 PM
HiNope not a 73 Bathurst fan ...
Or an XU-1 fan.
Bazza
#5 _LGN347/24C_
Posted 17 October 2007 - 07:13 AM
#6 _purpleLC_
Posted 17 October 2007 - 09:53 AM
Posted 17 October 2007 - 01:35 PM
Or an XU-1 fan.
lc inc gtr
As is normal, I am confused . Is it an LC XU-1 fan?
#8 _xuidave_
Posted 17 October 2007 - 04:22 PM
It's NOT an Xu1 fan but it is a Lc Gtr fan.Or an XU-1 fan.
lc inc gtr
D.
Posted 17 October 2007 - 07:41 PM
#10 _LGN347/24C_
Posted 17 October 2007 - 07:54 PM
Posted 17 October 2007 - 08:28 PM
Can someone with the LC parts catalogue post the XU-1 fan part number please?
I will compare the number with the LJ XU-1 fan (which is different to the other LJ 6s).
Bazza
#12 _tuffgong_
Posted 17 October 2007 - 09:05 PM
#13 _sunburst_metalic_
Posted 17 October 2007 - 09:52 PM
Posted 17 October 2007 - 10:11 PM
Thanks gong.2816157
That's a different number to the standard LJ XU-1 fan which is P/N 2823424.
As a matter of interest - P/N 2823424 is also the standard 6 cylinder LX fan (so probably LH also).
The '73 Bathurst fan is P/N 9934058.
Is P/N 2816157 the same for all LC 6 cylinders?
Bazza
#15 _Toranamuk_
Posted 17 October 2007 - 10:12 PM
That's what i have noticed on the cars that i have worked on.
Craig
Posted 17 October 2007 - 10:37 PM
There are 2 other part numbers for the sixes:
2250, 2600 (not S), 2850 (not S) � 2808186; and
2600S, 2850S � 2810488.
Posted 17 October 2007 - 10:59 PM
Thanks ZookBazza
P/N 2808186 is also correct for the LJ 2250 and 2850.
P/N 2810488 is also correct for the standard LJ 3300.
All in all it looks like the "rarest" fans would be:
The LC XU-1 .... P/N 2816157
and
The '73 Bathurst XU-1 .........P/N 9934058
All the other fans are found on a number of other Series and Models.
Bazza
#18 _LGN347/24C_
Posted 18 October 2007 - 06:33 AM
#19 _sunburst_metalic_
Posted 20 October 2007 - 11:55 AM
73 Bathurst only, unless it is an aftermarket job, the knotches clear the bolts for the Harmonic balancer spin off plate. SunburstDoesn't the XU1 & some GTR fan blades also have the trailing edge of the blade "notched" to clear the harmonic balancer retaining plate ??
Craig
Posted 21 October 2007 - 05:34 AM
