mixing clutch parts
Posted 18 February 2006 - 07:11 PM
I fitted a blue 6 flywheel and a red 6 pressure plate where an all red motor clutch went before...now it jams on the top of the bell housing...it looks like I have to go buy a new blue clutch kit.
I know the red motor has a physically bigger clutch pressure plate but it fitted before.
does the blue motor clutch have a lower torque rating?
Posted 19 February 2006 - 12:35 AM
RACV MAN
Posted 19 February 2006 - 07:45 AM
RACV MAN
Posted 19 February 2006 - 08:47 AM
I don't know if it is a 1 tonner clutch..it would help if I bought new parts once in a blue moon...I am originally from a farm (not the funny farm ) so I come from a long line of people who can make old things do what they were never meant to.
I will be pricing a blue motor clutch today...they are $150 on ebay
Posted 20 February 2006 - 08:33 PM
Blue motor clutch kit was $210 but I had to get it...the car has to be out by tomorrow.
I mounted the new pressure plate in the lathe and machined it...I also put a course sanding disc on the 9 inch grinder and sanded a section of the inside of the bellhousing where it made contact...fitted it all together it still hit.
So I got the die drinder and finished of the pressure plate and sanded some more..assembled it and it still hit...so i wound 2 bolts into the harmonic balancer and turned it over under it chewed thru..took it apart again and sanded it and now it doesn't touch.
Quite simply I need a blue motor bell housing..they must be different.
I know it all seems dodgy but fact is it has to go so what ever it takes to get it going....nah dodgy would have been to chisel the bell housing and angle grind the clutch.
But at least it all turns now and I can put it together tomorrow. Ready to hit the frog and toad!!!!!! i am a bit over the train..good perve but thats all.
Posted 20 February 2006 - 11:27 PM
Any way if it chews through you clutch will run cooler
Your flywheel isn't cocked on its spigot?
RACV MAN
Edited by rodomo, 20 February 2006 - 11:29 PM.
Posted 21 February 2006 - 01:46 PM
Gear bag is m20 aussie 4 speed 6 cylinder box....flywheel runs true.
I guess there is a revised bell housing for blue motors or the blue flywheel runs a little further away from the back of the engine but the starter still engages it....
I just thought someone around here would have done this before.
Posted 22 February 2006 - 07:57 AM
Posted 22 February 2006 - 11:44 AM
For those that are interested...no bad vibrations..I have had it pulling 5000 plus last night and no dramas other than the engine runs a bit hotter than i like..you get that with thin bores.
god it goes hard too! it is like a differnt car now.
Edited by FastEHHolden, 22 February 2006 - 11:45 AM.
Posted 22 February 2006 - 11:29 PM
RACV MAN
Posted 23 February 2006 - 07:35 AM
Just to clarify my original post..it is not possible to fit what I deem to a red motor pressure plate to a blue motor flywheel..they won't bolt up.
This is weird considering other here have had no problems but it is nearly sorted...I just need to space my inspection plate and fit a longer clutch push rod (read coach bolt)
