Rear Suspension Mods for circut Toranas
#1 _HatchmanSS76_
Posted 28 July 2008 - 02:16 PM
The upper and lower control arms are are still attached under IPRA rules but serve no purose now.
Some of the pics are a little blurred. It would be nice to get the car on a hoist but thats not likely to happen.
Posted 28 July 2008 - 08:54 PM
#3 _rorym_
Posted 28 July 2008 - 09:03 PM
Posted 29 July 2008 - 11:20 AM
#5 _HatchmanSS76_
Posted 29 July 2008 - 03:31 PM
R got it right in that it's a watts link setup. The torque arm is mounted from the diff to a secondary cross member.
Posted 29 July 2008 - 06:45 PM
The pics don't really do the great work justice. It's too crowed under there to get decent photos. No drawing to post either.
and that secondary crossmember is mounted through the upper arm mounts? to make it legal?
I have been thinking about making something similar if so
#7 _rorym_
Posted 29 July 2008 - 07:09 PM
#8 _82911_
Posted 29 July 2008 - 11:03 PM
Glad to see that more people are adopting this aproach to cure the Torana handling woes. This is the same system that I consulted extensively with Sam about.
If I could point out 2 potential problems....
The lower mount to differential housing needs to be reinforced and gusseted. Having a stud welded to a sheet metal housing with a rod end loaded in sheer on it is a recipe for diaster.The mount needs to be at least 16" square to distribute the load. Ideally I would delete this mount and pick up the mount off the front of the carrier mounting flange (plenty strong).
The fact that the torque arm is on the passenger side is a plus.
The big problem is that the rod ends are not IPRA legal when used in a longitudinal location, only in a lateral location device. The good news is that the articulation angles are almost negligable with this setup, so the use of DELRIN is encouraged.
Well done....
Cheers Greg..
