Hello
I have an LX thats getting converted to manual
As it has the auto accelerator/brake pedals can I just add the clutch pedal to them or do I actually still need to buy a manual accelerator/brake setup?
LX auto to manual - pedals question
_wozz_
, Aug 10 2008 02:41 PM
7 replies to this topic
#1 _wozz_
Posted 10 August 2008 - 02:41 PM
Posted 10 August 2008 - 02:56 PM
As far as I know, and thats not much, but the brake and clutch pedal are the same size in a manual, therefore a new manual pedal setup will be needed, not to mention a ratrap etc etc
Mitch
Mitch
#3 _Roadknight_
Posted 10 August 2008 - 08:51 PM
The auto brake pedal is wider than the manual brake pedal.
I havnt measured the gap but the auto brake pedal may conflict with the new clutch pedal.
#4 _73LJWhiteSL_
Posted 10 August 2008 - 09:51 PM
You will need a 'manual' brake pedal. The auto one will be too big.
Steve
Steve
Posted 11 August 2008 - 04:42 PM
Simply cut the excess metal off the auto brake pedal with a grinder.
Then refit the rubber pad from a manual or clutch pedal! Simple!
#6 _Sprog_
Posted 14 August 2008 - 05:10 PM
Replace the foot park brake with a hand brake and there should be heaps of room.
no need to change the brake pedal
Posted 14 August 2008 - 05:19 PM
then there is the question of which of the three clutch pedals you intend using
#8 _wozz_
Posted 14 August 2008 - 06:21 PM
Geez i'll have to check size of it when I get the car out of the garage next!
Not much room to move around in there and last time I tried something (put rear seats in) with it in the garage took a nice of new paint off :( lucky you can only see it when the door is open at least
