is this a L34 water pump?
#1 _LXXXIV_
Posted 19 February 2009 - 07:46 PM
Posted 19 February 2009 - 08:06 PM
Posted 20 February 2009 - 05:57 AM
There is nothing unique about an L34 pump, it is the same an any other LH V8.
Dr Terry
#4 _Herne_
Posted 20 February 2009 - 09:33 AM
Yes, this appears to be a normal HQ/HJ/LH V8 water pump housing, which would make it correct for an L34.
Dr Terry
I thought and was hoping that was the case Wasn't game to state it though.
Herne
Posted 20 February 2009 - 10:33 AM
#6 _LXXXIV_
Posted 20 February 2009 - 04:55 PM
what options do I have re: internals? can you still buy these ?
Posted 20 February 2009 - 10:01 PM
Posted 23 February 2009 - 04:08 PM
I can overhaul these for you, but you will need another old pump off any V8, for the front hub & the impeller. I don't have any spare ones of those.
Fitting a new shaft, bearing & seal kit is the only way to keep a factory looking pump.
Dr Terry.
Posted 07 May 2021 - 01:49 PM
Hey Dr Terry,
Do you still have the capability to overhaul original water pumps? Could a GMB WP808CG pump be used as the sacrificial lamb?
Posted 07 May 2021 - 01:56 PM
early Holden nut
Posted 07 May 2021 - 02:14 PM
Was just thinking it might be a good idea to get a new bearing/seal/impeller in this pump that I have.
Posted 07 May 2021 - 02:30 PM
early Holden nut
Posted 08 May 2021 - 11:27 AM
Posted 09 May 2021 - 03:26 PM
Looks to be the same single heater outlet as the water pump housing that came off my L34. So I’d say yes.
