Bush removal tools
8 replies to this topic
#1 _OtG_
_OtG_
Posted 22 March 2009 - 03:01 PM
I'm in the process of pulling my suspension down (front and rear) for rebuilding while the body is away being tarted up!
Has anyone had experience with bush removal tools like this one -
and has anyone seen places selling something like this locally? I'll check with some local tool places through the week, but thought someone here might know.
Originally I'd intended to just take all the bits to the suspension place to get the new bushes fitted since I don't have a press. Unfortunately it'll be a PITA for me to transport the entire diff housing to get the rear upper trailing arm bushes done so I figure if I can get my hands on a tool like this it might be far simpler to do it all myself..... this particular kit sells for $75-$80 USD so it's not expensive... in fact while researching I have heard of Pedders charging $15 per bush or something to replace them, so the tool would just about pay for itself too.
Edited by OtG, 22 March 2009 - 03:01 PM.
#2 76lxhatch
  • 7,151 posts
Posted 22 March 2009 - 05:01 PM
Front bushes are heaps easier in a press (just have to find suitable pieces to support everything). Doesn't work with the bushes in the diff of course though! That kit is only really any good value for money if the bits and pieces are a perfect fit - just as easy with a length of threaded rod, a couple of nuts, and suitable diameter thick washers with a short length of pipe. You probably have enough bits and pieces lying around to do the diff bushes without spending any money.
#3 Antelope Hatch
Antelope Hatch
  • 21 posts
  • Name:Ben
  • Car:L32 LX Torana Hatch
Posted 03 November 2018 - 07:05 PM
For anyone who has been searching for a cheap way to make a tool to assist with removing front suspension bushes, I found a 40NB gate saddle is a very good fit and only costs $20.  A quick hit with the file to give it 44.0mm across the face and it slotted into the suspension arm to give support while you're pushing out the bush.  If you don't provide support while pushing out the bush, you will risk cracking the suspension arm.
Attached File  IMG_4648.JPG   180.38K   16 downloads
Attached File  IMG_4651.JPG   155.1K   14 downloads
A suspension arm that I rejected because it had been cracked and repaired many years ago:
Attached File  IMG_4650.JPG   101.63K   17 downloads
#4 RallyRed
  • 7,836 posts
Posted 04 November 2018 - 11:27 AM
good tip....thanks
#5 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 04 November 2018 - 12:36 PM
Kinda like this.
Attached File  577A497D-40EC-4CA6-9EBD-99A046078D8C.jpeg   409.88K   17 downloads
Attached File  A645ABBD-41EA-4C3C-A1CD-1B616E90AFE4.jpeg   311.4K   14 downloads
Attached File  8E1CB8E9-3C91-42B6-8197-C582366B5530.jpeg   536.98K   14 downloads
#6 koalasprint
koalasprint
  • 295 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 05 November 2018 - 10:55 AM
I've used the threaded rod, cut down lengths of pipe and washer method. Works fine on the bench with trailing and control arms. But it was a real bastard on the diff. Not much room under there and the damn things must have been in there for forty years. Bent a few washers, you have to make sure the "pushing" piece matches up with the old bush perfectly. Otherwise is catches and goes crooked. When mine finally moved there was an almighty "CRACK!"... closely followed by some celebratory curse words.
#7 Antelope Hatch
Antelope Hatch
  • 21 posts
  • Name:Ben
Posted 13 November 2018 - 07:42 PM
Just want to correct a measurement on my post - it should be roughly 40mm wide across the bush (make sure you don't accidentally hit the zero button on your cheap Aldi vernier caliper when taking photos!!)
Attached File  IMG_4674.JPG   129.83K   10 downloads
For anyone who has been searching for a cheap way to make a tool to assist with removing front suspension bushes, I found a 40NB gate saddle is a very good fit and only costs $20.  A quick hit with the file to give it 44.0mm 40.0mm across the face and it slotted into the suspension arm to give support while you're pushing out the bush.  If you don't provide support while pushing out the bush, you will risk cracking the suspension arm.
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 November 2018 - 09:21 AM
Presses are as little as $250 roughly from machinery house, you'll save that on 1 or 2 car's, and probably use the all thread, threaded rod or booker bar, whatever your shop wants to call it for the other bushes as stated & you should be all good. Gary.
#9 caterham2
caterham2
  • 348 posts
  • Location:Mansfield North East Victoria not the other one in QLD
  • Car:Ford Focus RS AWD Gone over to the dark side .. Mercedes-Benz SLK350 Ford Cortina 2 door MK1 Twin Cam
Posted 15 November 2018 - 09:44 PM
Was going to suggest "Lady Gillette" till I saw the photos
