LX Hatch ID enquiry. What does "Coupe A" mean?
64 replies to this topic
#1 _Big T_
_Big T_
Posted 08 June 2009 - 07:30 PM
Had a call from a bloke who picked up an LX SS roller (202). On the tag that lists the ADR's is says "TORANA COUPE A". On this blokes other hatch is says "TORANA COUPE"
What does the "A" mean on the SS, if anything?
Cheers,
Tony
Edited by Big T, 08 June 2009 - 07:31 PM.
#2 rodomo
  • 17,999 posts
Posted 08 June 2009 - 11:11 PM
Cancelled my post, error, error :D
Edited by rodomo, 08 June 2009 - 11:22 PM.
#3 yel327
  • 13,085 posts
Posted 10 June 2009 - 12:47 PM
I've seen that before too and wondered. I'll have a look at all the ID in my collection and see what they say. I've seen variations in utes, statesmans etc on the ADR plate description before and without looking any further simply put it down to assembly plant variations. However except for a few early LH's, LH-UC should all be Dandeong build so you'd think they'd be the same?
#4 MRLXSS
  • 12,396 posts
Posted 10 June 2009 - 01:43 PM
Hmm, thats different... Maybe its 1/3rd "A"9X HAHA!
#5 76lxhatch
  • 7,153 posts
Posted 10 June 2009 - 02:12 PM
Could it be referring to the ADR? (27A vs 27)
#6 Toranavista
Toranavista
    'Let There Be Rock' 1977
  • 2,862 posts
Posted 10 June 2009 - 02:32 PM
Nope not ADR 27 vs 27A as I have seen it right through to Jan 78. On sedans as well. Perhaps it signifies a change in any ADR rule. This would alert them to make sure the chassis was samped with the correct ADR prefix ie ALX. BLX. CLX. DLX. I have seen plenty of CLX Toranas with the C crossed out and a D restamped. Built before the new ADR but not yet presented for compliance.
#7 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 10 June 2009 - 05:51 PM
A picture is needed here but most likely a mistake.
#8 GML-31
Posted 10 June 2009 - 05:53 PM
incorrect stamps aren't that unusual, I have a mate with a HQ statesman where they were stamped upside down
#9 yel327
  • 13,085 posts
Posted 10 June 2009 - 06:45 PM
Most early Adelaide Holdens (pre HX) are stamped upside down on the BODY plate, and also all pre Monaro Pagewood HK. My early HK GTS327 from Pagewood has half the VIN stamped upside down too.
I have the following:
UC Torana sedans that have no A: 5/78, 6/78, 3/79;
UC Torana coupe with no A: 2/79
LH SLR with no A: 8/74, 9/74
LX sedan with no A: 2/78;
LX SL coupe with the A: 12/77;
LX SS coupe with the A: 8/77.
My old 2/76 SL coupe also used to have the A.
It's not an ADR thing or all HJ-HZ would display it for BHZ, CHZ etc also. Looking at dozens of HQ-HZ Sandman, Monaro, tonner, Premier, Statesman etc examples in front of me there is very few A examples, although I found the following:
9/77 HZ GTS sedan, Pagewood build, "Holden HZ Sedan A"
6/77 HX BO6 van, Pagewood build, "Holden HX Panel Van A"
#10 Toranavista
Toranavista
  • 2,862 posts
Posted 10 June 2009 - 07:37 PM
Yes agree it is no mistake at least
#11 _Big T_
_Big T_
Posted 10 June 2009 - 08:00 PM
Maybe they are all Brisbane cars hey (A).... gedit !!
#12 _Squarepants_
_Squarepants_
Posted 10 June 2009 - 08:35 PM
Could be a rare Canadian model, ey???
#13 _a9xno25_
_a9xno25_
Posted 10 June 2009 - 09:25 PM
?Not un common on SS toranas. I had 76 SS with the same markings. No one on this site could answer that question then either.
#14 slx 050
slx 050
  • 115 posts
Posted 10 June 2009 - 10:43 PM
My 7/76 LX SS has the same ADR tag.... Coupe A
#15 TerrA LX
Posted 10 June 2009 - 11:15 PM
As Big T said, you have the coupe and Brissy had the coupe ey, er A.
Im thinken it is an ADR27A thing, can confirm pre 6/76 are coupe, no A.
#16 LX2DR
LX2DR
  • 1,763 posts
  • Name:Paul
Posted 11 June 2009 - 12:17 AM
Just checked my 12/77 hatch, it has the same, Coupe A, Dandenong built.
#17 76lxhatch
  • 7,153 posts
Posted 11 June 2009 - 07:49 AM
8/76 (ADR27A) with no extra 'A'
#18 GML-31
Posted 11 June 2009 - 08:38 AM
7/76 SS with Coupe A
is an auto
#19 yel327
  • 13,085 posts
Posted 11 June 2009 - 08:45 AM
It is possible since LX had ADR27A introduced mid model and would also explain why it's not there on the UC sedans and coupes I have. BUT if that were the case it'd also be on LX ADR27A sedans which it isn't on the examples I have, and it doesn't explain why it's on the HX and HZ I have. And not on others from the same plant. I'm almost certain my old 2/76 SL hatch had it too. My guess is it means something else. I'll ask Dr Terry and Ben Stewart and see if they know.
#20 76lxhatch
  • 7,153 posts
Posted 11 June 2009 - 09:48 AM
is an auto
Maybe it is that simple?
#21 yel327
  • 13,085 posts
Posted 11 June 2009 - 10:45 AM
I sent emails off to Ben AND Dr T and suggested the same thing, ie A = AUTO.
Maybe it's because on ADR27A Holdens there is a different engine spec between Auto and Manual, eg XQL vs HL. Also manual 308 is a different engine to auto (lack of EGR valve for example on manual).
All the 4 x examples I have with A are autos:
LX SS L31 M40;
LX SL L32 M40;
HX Van L31 M41;
HZ GTS L31 M41.
From memory the LX and UC Torana sedans are all manuals.
I wonder...?
#22 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 11 June 2009 - 12:24 PM
My Ex G/F
Had a UC Torana,that had UR on the A.D.R Plate,where UC was ment to be,i rang Holden Customer Service up,they checked there records on it,and they said it was a mistake from factory,simple as that,so i say the A on yours is same thing.
But my Ex G/F still thinks she had a UR Torana,the Only One LOL,or was there a UR Torana Coming
#23 fuzzypumper
fuzzypumper
  • 929 posts
  • Name:Archie
Posted 11 June 2009 - 12:58 PM
Seriously? :huh: Are you saying all ADR27A 308 manuals had no EGR valve? I'm perplexed now. What about 253 manuals?
BTW my hatch is 12-77 with just "COUPE" on plate(no A) and was a factory manual.
#24 yel327
  • 13,085 posts
Posted 11 June 2009 - 01:05 PM
My Ex G/F
Definitely won't be an error in my opinion. Too many of them are like it. Errors are normally confined to either wrong letters/numbers where another one should be (like the UR) or repeats in chassis or engine numbers leading to R, R1, R2 etc on the end. I've never seen any instance of an error with a random letter or number appearing on Holden ID plates, particularly this many, in the 25 odd years i've been studying Holden ID plates.
I saw another repeated HZ chassis number the other day too (on both chassis and ADR plate), ie AHZxxxxAR. I'm yet to see an R1 or R2 but they supposedly exist.
#25 xu2308
xu2308
    Grail Hunter
  • 4,704 posts
  • Name:AL
Posted 11 June 2009 - 01:26 PM
I Rang holden up,they said it was a error from factory,or you saying it was a UR Torana LOL
I say it was a Monday Car the UR after the GMH Employee had a big weekend and dident run the stamp machine very well i reckon.
Any way GMH Customer service said is was a Error and No UR Rana
