Ford T5 confirmation
8 replies to this topic
#1 _coxt0001_
_coxt0001_
Posted 11 June 2009 - 11:25 AM
Hey guys i am just wanting to get some confirmation in regards to the Ford T5 gearbox. I have read a few T5 posts and many mention that the Ford T5 gear shifter comes through the original hole in a LX Torana (requiring no cutting). Can anyone confirm this? Also what series Ford is this T5 from? Cheers
#2 _@milco@_
_@milco@_
Posted 12 June 2009 - 12:06 AM
e series fords have the T5 fitted
#3 _uc304_
_uc304_
Posted 14 June 2009 - 02:44 PM
i have a t5 from an eb falcon in my uc i had a commodore t5 with a cracked case but good gears so i got an eb box with a striped clustershaft swaped the gears over and used commodore bell housing the diference is in the extension housing the shifter sits about an inch forward of the commodore and the mount sits further back. i had to cut probably 2" back of the original hole to get the shifter through. im guesing the lx has a similar shifter hole so you will probably have to do some cuting.
Attached File  smal_shifter.JPG   55.89K   33 downloads
#4 _The Baron_
_The Baron_
Posted 14 June 2009 - 10:43 PM
Is there a difference in the input shaft length too?
#5 _82911_
_82911_
Posted 14 June 2009 - 11:03 PM
ford input is 194mm and the Holden V8 is 212mm.... Don't ask me how I remember that.....
It is an expensive memory! :fool:
#6 _slr253_
_slr253_
Posted 18 August 2009 - 07:43 PM
If you were to buy a Ford T5, a Holden bellhousing and Holden input shaft, would that fit in a LH sedan?
If so, what crossmember do you use? Is there anything else?
#7 Statler
  • 6,332 posts
Posted 18 August 2009 - 07:48 PM
The Ford box will only fit on the VR commonwhore bellhousing.
But.....then the input shafts are a different length.
Roodog should be chiming in soon...............LOL
Can you put the Fraud rear extension on the commonwhore box?
I will let you know.
Edited by coolngroovy, 18 August 2009 - 07:53 PM.
#8 _darrenmark1_
_darrenmark1_
Posted 18 August 2009 - 10:19 PM
Comon Roo spit it out...your the expert!...took us long enough to find out all this stuff should be in the memory bank somewhere!
#9 _uncleian_
_uncleian_
Posted 19 August 2009 - 09:37 AM
At this stage i can only tell you that the FORD T5 is shorter than the commodore one.
It does fit straight thru the existing hole in the tunnel.
If you give Dellows a ring they can give you a price list of the things you need.
I do have all this info but it is all the a very dead PC.
ROO
