Light Strong Diff?
38 replies to this topic
#26 _Viper_
_Viper_
Posted 23 June 2009 - 09:23 PM
So like a 1-way LSD? So is "Lokka" a brand then?
And yea Ive done Plenty of research, There is always someone asking about LSD in a Gem on the ozgemini.com forums and the same info is always given... Early model Commodore center is the only one that fits.. But ill ask the question again, directly about Torana Diffs.
p.s. Early model gems had a small salisbury (TX - Mid TC) (Mid TC-TG all had borgwarner)
#27 _sloshy_
_sloshy_
Hilux axles are 30 spline!
Heres a broken one out of my hilux:
#28 76lxhatch
  • 7,152 posts
Posted 23 June 2009 - 09:25 PM
Similar concept to Detroit locker but different operation:
http://www.4wdsystem...index.php?id=29
#29 _sloshy_
_sloshy_
Posted 23 June 2009 - 09:27 PM
Lokka is made by 4wd systems and is similar to a detroit locker.
#30 _Viper_
_Viper_
Mmmk well on every website ive found info on hilux diffs they say 31spline
Terra LX are you saying a UC salisbury center will fit into the early TX Gem salisbury housing? or that the Banjo center will fit into the Borgwarner housing?
#31 TerrA LX
Posted 23 June 2009 - 09:38 PM
One housing is B/W and fits all B/W stuff, the other is the small saulsbury type, all bango from HR to LX, all uc and all commodore thru to VH, early Vk use parts that interchange, thats where they get their LSD's from for the second mentioned diff.
The gem B/W diff interchanges wit most of the same B/W stuff including the lokka centres.
Hope that helps.
If you can't search B/W on ozgem or need more info I will have to dig my old drive out.
Hope that helps.
#32 _Squarepants_
_Squarepants_
Posted 23 June 2009 - 09:49 PM
I've had 2 different Hilux diffs apart and both were 31 spline.
#33 TerrA LX
Posted 23 June 2009 - 09:59 PM
my memory is a little rusty, something tells me that the gem B/W is smaller than the commodore/falcon ones.
Sorry for the bum steer.
Best bet is to set it up like the old GTR racers did with a bango detroit and gemini axles.
Remind myself to stop using crap english like commy, must make it harder to search)
#34 _sloshy_
_sloshy_
Posted 23 June 2009 - 10:04 PM
Then count again :spoton:
#35 warrenm
warrenm
  • 2,106 posts
  • Car:1972 LJ Torana
Posted 24 June 2009 - 08:50 AM
Definitely 30 spline :spoton: on the Hilux diffs.
Warren
#36 _Bomber Watson_
Posted 24 June 2009 - 09:37 AM
Hilux diffs have three different centres boys....
Afaik 2 are 30 spline and one (diesel 4wd) is 31 spline....But dont quote me on that.
#37 _sloshy_
_sloshy_
Posted 24 June 2009 - 08:00 PM
All 8" hilux, 4 runner and surf diffs are 30 spline and all are interchangeable front to back, 2wd-4wd, petrol-diesel doesn't matter, but ifs fronts are different,they aren't 8".
#38 _Viper_
_Viper_
Posted 24 June 2009 - 08:28 PM
Thanks guys, anyway 30 or 31 spline not much difference... ALOT better then the 23 spline stock diff :)
#39 _Viper_
_Viper_
Posted 26 June 2009 - 07:48 PM
Ok I checked on the Ozgem forums and Found that Yes a UC Center will fit into a Gemini housing! But yea arnt the LSD centers for UC's rare as and not that strong???
Is there a lokka available for a UC diff?
Ill shoot a e-mail off to the company anywayz
