RED LC 4 dr
32 replies to this topic
#1 limo
limo
  • 2,672 posts
Posted 09 July 2009 - 09:35 PM
don't know why but I thought it would be easy / quick finish off and I have 2 others I should be working on first
Picked it up about 3 weeks ago, 2 station wagons, car carrier and 6x4 cage trailer
lots of bits, haven't sorted yet
in the depot shed
the front and engine bay, before
replace rad support, headlight section, prime with red oxide, clean up engine bay
black paint
replace tunnel section
before
after
windscreen section, rest is good, back and front
front floors
other rust cut out, speaker holes
dash section
doors off so the frames can be tidied up and painted red, the door edges as well
Edited by limo, 09 July 2009 - 09:37 PM.
#2 _panthervs_
_panthervs_
Posted 09 July 2009 - 09:49 PM
looking good mate wat are the plans?
#3 _tyre fryer_
_tyre fryer_
Posted 09 July 2009 - 09:51 PM
Wow Ken, I didn't realise you had all going so early.
You really can outdo yourself sometimes... It's great to see this car coming along.
there were some bits and pieces on that car I had my eyes on.
Might have to come up for another visit sometime soon.
Keep the updates coming, plenty more pictures!
#4 limo
limo
  • 2,672 posts
Posted 14 July 2009 - 07:39 PM
my plans, 186 with WW carby and extractors, aussie 4 spd (cable clutch), LSD 3.36
will proberly get LJ seats, trim and GTR dash / dash pad as I want to keep my LC bits
mags but not looked at what I have yet
an update
don't you love buffing old paint to find bog hiding rust holes
such as
all holes filled with wedled sections
floor sprayed with GMH sealer, other pieces primed
haven't woeked out what to do with heater control panel in dash yet, proberly fill in and use LJ under dash panel.
Matt have some extractors and yella terra head to go, other bits to add, let me know what interested you
#5 _tyre fryer_
_tyre fryer_
Posted 14 July 2009 - 08:14 PM
I just wanted the steering wheel/boss kit and the antique gold passenger seat off the other car you have.
Was also keen on the exhaust but had one made up this week to clear the custom crossmember so no matter now.
Looks like it'll be a great little car when done.
#6 _jamesl1600_
_jamesl1600_
Posted 17 July 2009 - 06:15 PM
its looking good ken, wish i had the time to finish it off.
will make sure i post that paper work for it. been busy with boat show
#7 limo
limo
  • 2,672 posts
Posted 20 July 2009 - 08:52 PM
another hiccup, things to fix
one of the mounting points on the lower wishbone for the shocker is broken and all the bushes look like 40 yr old originals
so out it came, bushes coming from Rares
#8 limo
limo
  • 2,672 posts
Posted 02 December 2009 - 07:57 PM
after a 3 month break while I shifted depot/office, new building had to build new offices, moved and sorted lots of gear and cleaned up old shed I have started working on this one again
the door sides/edges painted to match
door jams on the car same deal
front and back screen sills, engine bay, rad support
repaired and finished off front guard fronts
now to put it back together then cut and polish
Edited by limo, 02 December 2009 - 08:04 PM.
#9 lcgtr1970
lcgtr1970
  • 1,702 posts
  • Name:Jordan
Posted 02 December 2009 - 08:34 PM
coming along nicely mate. well done.
#10 Heath
  • 18,312 posts
Posted 03 December 2009 - 10:59 AM
That came up beautifully! Nice work
#11 _tyre fryer_
_tyre fryer_
Posted 21 January 2010 - 07:27 PM
Lurking old threads.
What happened to this car? Still working on it Ken? I'm keen to come up and see the new depot and the projects you have lurking around there.
Still keen on that passenger seat, or even more interestingly... Did you happen to acquire those front sports seats with torana rails that James had with that car? Interested in upgrading the interior for more comfort.
#12 limo
limo
  • 2,672 posts
Posted 21 January 2010 - 07:56 PM
I have done some more, motor, gearbox, lights, doors back on with fittings, brakes, bonnet hinges, heater box
will post more pics when I get time
got the seats organised, out of LJ from the farm, heaps of other parts as well
so many little bits to clean/repair/tidy up, I would hate to have one car and no donors,
parts of at least 4 cars so far to get good bits
having issues with a hood lining I bought on line holding me up,saps my interest
seller said it was copy of an original but it doesn't fit (short- front to back), I measured it against an original, he says I'm not an experienced fitter,
I got couple of sets of seats from James but don't think either had Torana rails, will check though
call if you are heading up the hill some time
Edited by limo, 21 January 2010 - 07:57 PM.
#13 _tyre fryer_
_tyre fryer_
Posted 21 January 2010 - 08:23 PM
Certainly will Ken, might wanna hide some fo your donors as I've been living on the forums as of late (been home sick with waaaaay too much time) and I'm itching to get this and that done to my car and have the feeling that I'll be wanting to raid alot more of your spare parts.
Yeah, check those rails when you get a chance as I think James told me that those seats were modified for torana when I was looking at buying the car.
#14 _jamesl1600_
_jamesl1600_
Posted 23 January 2010 - 07:39 AM
looks good ken, shame i didnt get around to finishing it. awell will be gettin another soon
#15 limo
limo
  • 2,672 posts
Posted 23 January 2010 - 05:29 PM
Another hold up today,
thought I would finish fitting gearbox (had to over haul the shifter, held me up ) then start on other underneath bits
not likely, there are 4 tapped holes in the chasis rails missing, appear in 70 on models for trimatic/3 spd trans,
so there is nowhere to bolt up the m20 cross member, original was opel
so I hope the heavy metal plate that is fitted inside the rail with the threaded holes extends back as far as the in later models to allow me to drill and tap the mounting holes I need
may drill pilot holes tomorrow
#16 _tyre fryer_
_tyre fryer_
Posted 24 January 2010 - 05:24 PM
Gee, sounds like alot of fun ken, NOT. I remember muckiong around trying to make custom crossmembers etc, gave up and bought a dellow one, and it still resulted in another week of mucking around, now you're back on here James, Maybe you could fill s in on those 'sports' seats. are they on torana rails?
#17 _jamesl1600_
_jamesl1600_
Posted 25 January 2010 - 08:04 AM
if ya mean the black an green seats all i know is there out of an early jap car so i was told.
an not on torana rails
#18 limo
limo
  • 2,672 posts
Posted 25 January 2010 - 10:19 PM
I welded up about a dozen 3/8th holes in the floorpan in the seat mounting area so I would say people just drilled holes in the floor to fit diff seats and didn't use original mounts
fitted the crossmember today, front holes drilled and tapped into the reinforced section but back ones through chasis and floor with bolt and crush tube same as towbar system,
#19 limo
limo
  • 2,672 posts
Posted 09 March 2010 - 09:09 PM
an update for those interested, I don't get much time to work on it as business is hectic again, always seems more to do on the parts I put back together.
body back together, lots of bits to cleanup and fit, have new rubber kit waiting
engine and gearbox in, exhaust done,2", cable clutch on the way
not a nice look so will have to operate on a donor 4cyl 2 dr for a transplant
#20 debkar
debkar
  • 911 posts
  • Car:1971 LC 2 Door
Posted 10 March 2010 - 06:34 PM
Looking very nice indeed,
Regards Simon
#21 Potta
Posted 10 March 2010 - 06:44 PM
That is a brilliant colour....Is it Salamanca Red?
I keep thinking I'll do mine in a red but shying away because everyone does red but I don't really care anymore cause it looks awesome....
Look forward to seeing the finished product.
#22 limo
limo
  • 2,672 posts
Posted 11 March 2010 - 06:47 PM
don't know the colour as it was partly painted when I bought it, local paint guy I use for work cars went through about 50 reds and thought it was a ford colour,
I took the boot lid to a paint supplier, they polished it and matched the colour in 2 pak.
bloody good match and comes up good straight from the gun, haven't cut and polished yet
#23 limo
limo
  • 2,672 posts
Posted 20 April 2010 - 07:40 PM
uploaded some more pics, further along than this but have to take more pics
more fun,
rh handbrake cable siezed
crack in outer tube of steering column
thread stripped on carby for needle and seat
don't you love people who grind back inlet manifold tabs to fit extractors?
built them up to suit GTR headers
will add to list when I take more pics
#24 limo
limo
  • 2,672 posts
Posted 22 May 2010 - 03:20 AM
getting closer, might get on a cruise soon
fired it up last week and drove around carpark
problem with brakes though, rear cylinders siezed and when I took them out they were for drum front end so who ever fitted disks on front didn't change the back
the hood lining was a bugger to fit, bought it off feebay and was too short so had a trimmer measure and replace one panel, he added 20mm but I reckon it should have been 30mm
had to heat it up and stretch and stretch and stretch
front screen in, will do back tomorrow
starting to look like a car
#25 _TJ308_
_TJ308_
Posted 22 May 2010 - 03:25 AM
Looking great! bet u can't wait to drive it
