XU-1 starter ID
30 replies to this topic
#1 _twin turbo HT_
_twin turbo HT_
Posted 03 August 2009 - 11:30 PM
Anyone tell me the part No for an LC XU-1 starter motor ? (bosch or lucas) ?
#2 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 04 August 2009 - 12:32 AM
Hi
The LC parts catalogue only gives one P/N for the 186X starter motor - that being a Bosch P/N 2812679
Bazza
#3 _rogered_
_rogered_
Posted 04 August 2009 - 09:27 AM
Thats a good one
Are the starters different between std cars and XU1?
#4 Zook
Zook
  • 1,536 posts
Posted 04 August 2009 - 07:39 PM
The parts book says that the motor which Bazza has given you the number for was also fitted to the 2600. It seems that Lucas starter motors were the other choice (but not for XU-1) and these were also fitted to 2600 motors as well as the 2850. My book has a pen amendment which reads '9947262B' as a possible alternate for the 2812679 starter motor.
#5 _inj88u_
_inj88u_
Posted 05 October 2009 - 07:27 PM
Can any one tell me the alternator number please? thanks
#6 _inj88u_
_inj88u_
Posted 05 October 2009 - 07:36 PM
Is the part number 9120060600 i not sure? thanks again
#7 _BATHURST-32D_
_BATHURST-32D_
Posted 11 October 2009 - 05:08 PM
i will give you these numbers.
bosch lc from 1969 to june 1971
9000063009
this number is also a 138 motor number.
from june 1971 to may 1972
9000063014
from may 1972
9000063025
but please note with all these numbers above there is another part number that you can refere to been BXH134
cheers gong.
#8 _BATHURST-32D_
_BATHURST-32D_
Posted 11 October 2009 - 05:23 PM
also the alternator bosch
lc-xu1 to june 1971
9120600679 35a
from june 1971
to may 1972
9120060679 40a.
cheers gong
#9 _oz772_
_oz772_
Posted 03 October 2010 - 10:46 PM
Hi
Bazza
I see in the LC parts catalogue 2812679 for the 186X starter motor, as Bazza has said. However, the LC XU1 supplement shows the part number for the complete starter assembly as 7431089, though it isn't listed as a New Part. And yet, all the part numbers in the XU1 sup, for the bits that make up the starter motor, are identical to the LC parts catalogue. Does anyone know what this 7431089 is?
#10 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 03 October 2010 - 11:04 PM
Hi
Bazza
Hi
That's odd. 7431089 is mentioned in the numerical index at the back of the Feb '72 LJ catalogue - but doesn't get a mention in the body of the book at "2.041 MOTOR ASSEMBLY - Starter" where it should be.
Bazza
#11 S pack
  • 15,539 posts
Posted 04 October 2010 - 12:02 AM
Hi
Bazza
Hi
Bazza
Sorry Bazza, recheck your parts book.
LC parts catalogue M37090 October 1971.
Group 2.041 Motor Assy - Starter
Motor Assy - Bosch - 2600 eng - 2812679
Motor Assy - Bosch - 186X eng - 7431089
Dave
#12 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 04 October 2010 - 06:12 AM
[/quote]
[/quote]
Dave
[/quote]
Hi Dave
No need to be sorry, Part Number 7431089 is definately not there - I don't know what edition I have (front cover missing). I thought it was the latest because it has the 2850, 2850S and CK parts.
My most recent comment was more to do with the anomaly in the LJ catalogue.
Bazza
#13 _oz772_
_oz772_
Posted 04 October 2010 - 07:35 AM
Thanks Bazza. All a bit strange, especially since all the parts in the XU1 supplement that make up the starter have identical numbers to the LC catalogue part numbers. Also strange it doesn't have the N.P. (new part) designation next to it in the LC XU1 sup.
Edited by oz772, 04 October 2010 - 07:36 AM.
#14 S pack
  • 15,539 posts
Posted 06 October 2010 - 09:01 PM
Hi Bazza
Checked my Feb 72 LJ parts catalogue and found the same anomaly with that part number listing.
My catalogue also contains a second loose leaf numerical index which is obviously a GMH parts book update to rectify errors and it doesn't have the 7431089 part number listed.
I thought your LC parts catalogue might be the earlier 1970 blue cover edition but if it was it wouldn't have listings for the 2850 engines. Very Strange indeed.
Dave
#15 _oz772_
_oz772_
Posted 06 October 2010 - 11:26 PM
I suspect the XU1 supplement is a later edition and is in error; I suspect someone has transposed an LJ part number into it. That's my guess...
#16 S pack
  • 15,539 posts
Posted 07 October 2010 - 01:59 AM
No, the XU1 supplement comes after the very 1st LC parts catalogue which would have been published sometime before the XU1 was released. Most likely starter motor Pt No. 7431089 came straight from the HR or HK,T,G 186s engine so would not have been listed in the LC XU1 supplement as a new part as it was an existing part albeit in a different model.
Check out this post by GTRXU1. http://www.gmh-toran...showtopic=48613
#17 _oz772_
_oz772_
Posted 07 October 2010 - 09:29 AM
Ok. Would be interesting to see what the difference is in the two starters. Having a look at the parts that make up the starters, the numbers seem to be the same between the two.
#18 S pack
  • 15,539 posts
Posted 08 October 2010 - 01:07 AM
Strange isn't it.
Two supposedly different Bosch starter motors (probably different torque ratings) and yet all the service parts are the same.
#19 _Mike73_
_Mike73_
Posted 08 October 2010 - 01:33 AM
Hi Guys,
Looks like you all are starting to realise the traps of believing all you read, I have a page full of mistakes in the parts book just for the 73 models.
The parts books from memory indicate that 73 XU-1's had Bosch starters, yet my friend with a low milage 73 LJ has a Lucas starter and alternator.
I think the book is wrong with the late starters especially as weight saving for racing purposes must have been a consideration,
I have not rechecked the parts book lately though.
Lucas Torana starters are shorter than the Kingswood units and are much lighter than Bosch due to Aluminum windings, the Lucas Alternators are smaller and lighter than the Kingswood ones too.
Mike
#20 S pack
  • 15,539 posts
Posted 08 October 2010 - 02:54 AM
Hi Guys,
Mike
Hi Mike
Yeah I've known for years that parts books have mistakes. I did some time back in '85 as a Holden parts interpreter.
I also have quite a number of GMH letters advising dealers to update mistakes in parts books.
Another reason for part numbers that may not match between earlier editions and updated editions of parts books is supercession of parts. Sometimes a revised part from later production of a current model would be suitable to earlier production models so when an updated catalouge came out only the later part number would be shown as the earlier part would be discontinued.
Another thing I have learned is sometimes parts were be found to be inherently lacking in quality or durability so a new and improved part was produced and GMH would instruct Dealers to replace the faulty part/s when the affected vehicles came in for service without even a word to the owner about what they have done.
Also parts would be superceeded by an improved part that may appear different in some way to the original part but the part number doesn't get changed.
Oh by the way, seeing as you want have a dig at my sign on name maybe VZ S pack will set your mind at ease.
#21 _BATHURST-32D_
_BATHURST-32D_
Posted 08 October 2010 - 06:56 AM
hahaha, the good old replacement parts books,,,
cheers gong
#22 _Mike73_
_Mike73_
Posted 08 October 2010 - 05:04 PM
Thanks S pack,
I am much happier now I know that you are referring to your VZ S pack, I have heard people using S pack in terms of LC LJ Toranas and of course there was no such thing!
I agree with the several ways the supersession happened ( would be a waste of time debating your knowledge ) a few parts that I have found that were superseeded and part number not changed of course were the engine mount plates, engine mounts and sumps.
Other parts that changed were the fuel sender, gear knob, 1974 GTR wiring harness.
Mistakes seem to be 73 Con rods, GTR guards in relation to optional 202 engine, Oil filler caps, heater hose bracket, various diff componets, pressure plates, Bathurst 72 and 73 carbies, Fuel Caps for 73
And there is no extractor, or front pipe pictures For the Bathurst 73 either
Mike
#23 Kockum
Kockum
  • 476 posts
Posted 28 October 2010 - 06:19 PM
Hi Guys,
Mike
Mike, I find it interesting that no one here has indicated they have a Lucas starter motor in their original LJ XU1.
Do you know the horsepower rating of the Lucas starter in your friend's car?
Like you have said, only Bosch starters are listed for the LJ XU1. These Bosch starters (P/N 2825508), 9000 063 025, are rated at 1.3 horsepower. SO presumably, your friend's Lucas starter should have this rating as well.
D.
#24 _macdou_
_macdou_
Posted 22 November 2017 - 09:57 PM
I always though XU1 Alternator 9120060679 is/was a 40a alternator. Bigger pulley, slower rotation, higher amperage to maintain charge rate, makes sense
Then this appears on FakeBook.
#25 _macdou_
_macdou_
Posted 22 November 2017 - 10:06 PM
I believe someone of this forum has a listing of Bosch alternators and guessing has rating....
