My proposed blasphemous project
#1 _niterida_
Posted 24 October 2009 - 05:47 PM
Looking for a UC or LX Hatchback - nothing unusual in that but what I plan to do to it is :
Would you believe Subaru motor (non-turbo) and AWD driveline ??
Plus another little secret that I don't want to share just yet.
Why a Subaru motor and AWD ? Because I am familiar with them and want modern running gear and AWD. I did think of a Nissan GTR setup but I think that would cost too much $$$$$
Please don't shoot me down in flames and say what a waste of a good Torana, or how it won't work etc etc. I have built modified cars and bikes before so I know what I'm doing.
Posted 24 October 2009 - 05:52 PM
Good luck with it.
Posted 24 October 2009 - 05:54 PM
But I'd go the R32 GTR parts myself
Theres a UC around here with the Skyline rear IRS clip already in it
Posted 24 October 2009 - 05:57 PM
Best you start out with a sunbudgie hatch then, being a four and all.
#5 _gen3torrie_
Posted 25 October 2009 - 02:36 AM
dig pit
open wallet
throw money in pit
#6 _billywest_
Posted 25 October 2009 - 06:24 AM
Hi - new to the forum and don't have a Torana yet but do have big plans.
hey niterida welcome to the forum good luck on the build when it gets started cheers billywest
Posted 25 October 2009 - 08:28 AM
If you actually do it, awesome, regardless of how you do it. But however that happens, it will be a lot of work. Make sure you're capable of seeing it through before you cut a good car up. I hope that doesn't come across negatively - I know nothing about your skills or experience
I would also opt for 32 GTR driveline but whatever you can make work is cool
#8 _torriechick_
Posted 25 October 2009 - 08:32 AM
Posted 25 October 2009 - 08:51 AM
Posted 25 October 2009 - 09:15 AM
#11 _niterida_
Posted 25 October 2009 - 09:56 AM
Wait I don't get it, I don't know much about Subarus but wouldn't the driveline suit a laterally mounted motor? What motor would you put in it and what orientation would it have in the car?
Subaru's are a longitudinal mounted motor - not transversely like most other japanese FWD/AWD cars. So it is going to have the Subaru motor as well as the gearbox and driveline.
Not sure about the rear end but the front is not going to be much work at all. The engine crossmember is no wider than the Torana chassis rails so it will bolt up OK, and the lower control arm mount will line up with the chassis rail too. The strut tops need a mounting point fabricated in the top of the wheel wells but that is easily done using a subaru wheel well. The chassis rails will need to be notched slightly since the Subaru motor is fairly wide but in terms of mechanical fitting that is it - all done !!
I would also go for a GTR but you can get a decent Subaru setup for about $2000 - how much is a wrecked GTR or Halfcut with rear diff going to cost ?
As for my skills - I put a Rotary in the rear end of my Beetle way back in the early '80s, a big block chev mounted between the seats in my CF Bedford and an RG500 motor into a KR1 250 frame with complete custom carbon fibre body work as well as lots of other little projects
Thanks for all the comments
#12 _Bomber Watson_
Posted 25 October 2009 - 10:01 AM
Plus that way you have a six, sorry but the Subaru motors just dont impress me that much. Especially NA.
First thoughts are Wha??!!?? but upon further thinking it could actually be a fair proposition. Torry is lighter than either a Scubi or a Skywine and both cars can show decent performance, so grafting all the gear into a lighter body would hold merit imo. Plus it would look a WHOLE lot cooler.
I think the front end would be fairly easy if you had a donor car, just cut the inner guards out of both cars and weld the strut set up into the Torana.
Getting it engineered is another problem.
If you dont want it registered, get the grinder out. If you do, then i would recommend talking to us less and an engineer a lot more.
Posted 25 October 2009 - 10:19 AM
Got a good engineer in mind?
Anyway it sounds like the goods to me
Posted 25 October 2009 - 10:46 AM
As soon as you start touching chassis rails and engineering in new shock mounting points (not to mention going from the traditional torana suspension to a mcpherson strut setup) would make any engineer run for the hills if you were trying to pass it as a "modified vehicle"
I notice you are in WA, might be worth PMing LS2LXhatch as he has a pretty in depth understanding of the rules and regulations that cover WA.
I wouldnt be going for the subaru driveline either, (as others have said) the skyline gear would be more powerful and alot better performer all round IMO.
Im all for modifying toranas, but something about the way they handle and drive (not perfect), is all part of the fun of owning/driving a torana, pushing the 30+ year old designed car to go quick in a straight line and round corners is kind of fun in itself.
Good luck with it (if you choose to go that way) might be cheaper to just buy a subaru and a torana and enjoy the best of both at different times.
Posted 25 October 2009 - 10:56 AM
#16 _Torrie_Man_
Posted 25 October 2009 - 11:28 AM
Get a stuffed one!
#17 _niterida_
Posted 25 October 2009 - 11:37 AM
Start with a skyline. About the same sized car as a UC.
Yeah GTRs are probably better, but as I said they are more $$$ and I know Subarus.
Cutting the whole inner guards off was exactly what I was planning.
I have an engineer I have worked with before so I know what is expected.
Registering it can't be any harder than registering a street rod. I am changing the suspension from one car to another, but I'm not actually modifying the suspension since it will be mounted exactly as it was in the Subie.would have to be engineered as a "one off vehicle" (cant remember the technical term, but its something along the lines of a self manufactured vehicle, lots of work)
Yeah it would probably be a lot easier to have a Torana and a Subaru but where would the fun be in that ?? Especially when you have an old car that looks cool but handles and drives (hopefully) way better.
Another reason for not going for the Skyline set up is a little idea I have that I am not going to share that will only work with the Subie engine
Posted 25 October 2009 - 11:46 AM
there r some pics here
http://www.gmh-toran...=1
#19 _Bomber Watson_
Posted 25 October 2009 - 11:59 AM
Street rods are based on a car built before 1940. Your working with a car built in the late 70's with later model parts going in, entirely different kettle of fish.
Not trying to scare you off, just sit down with your engineer and work everything out first.
#20 _niterida_
Posted 25 October 2009 - 12:15 PM
see, told you it would get a positive response
I am actually pleasantly surprised - I was expecting to be bombarded with hate mail. I myself am a big fan of valuable classic cars and hate seeing them butchered - I would never do this to an A9X of course but a worthless old Sunbird is open game
To tell the truth I was also thinking of doing the same to a Subaru Brumby, but they are just as hard to find as a hatch. And like hatches they are either rustbuckets or overpriced (personal opinion).
So it is currently a race to see whether I find a Brumby or hatch first..............................
#21
Posted 25 October 2009 - 12:20 PM
Are inspected by TAC 3 times before they get anywhere near the pits
They are a very different beast
Good luck though
And by the way... finding a 4wd nissan box is easy and sorta cheap
So to are rear cuts
Got me thinking though... Vh41 or VH45 Nissan V8 with AWD and IRS
#22
Posted 25 October 2009 - 12:42 PM
Maybe someone else has details?
#23 _niterida_
Posted 25 October 2009 - 12:54 PM
Its very different to a street rod mate.
Yeah I know it is different to a street rod but what I was getting at is the fact that they use suspension form a different model eg; Torana and mount it to different chassis but don't change the suspension and then get it engineered, so doing the same to a Torana and getting it engineered shouldn't be too hard. I went through the same thing with my RG500 bitsa - it had totally different rear suspension and swingarm but the engineer passed it OK after checking out all the movements, cog, welds etc.
So to are rear cuts
hmmmm - how cheap and easy to find are the nissans ? Would make for an awesome swap if you could mate the V8s to the boxes easily enough.
Maybe the GTR might be the way to go if anyone knows where to get a cheap front and rear cut or race-only import ?
I seem to recall a brumby up the central coast of NSW somewhere that had full WRX running gear.Its a few years ago that I heard about it,(I never saw it)
Yeah its been done before but not the way I planned - they generally modify the WRX gear to fit into the body and existing suspension setup. I planned to modify the body to fit the complete WRX dribveline and suspension, which is quite a bit wider than a Brumby so you need flared guards. In fact the WRX/Liberty's are slightly wider tracked than the Torana (by about 15mm)
#24
Posted 25 October 2009 - 03:56 PM
The big challenge would be fitting the strut front end to the Torana engine bay?
It wouldn't be the first to have that done....
Grant..
#25
Posted 25 October 2009 - 04:11 PM
