under dash clutch master cyl
Posted 14 December 2009 - 06:25 PM
What parts did you use?
What problems did you encounter?
Set up would preferably work with hadfield slave cyl setup (holden V8)
Also looking to not add new holes or bolts to the firewall.
Posted 14 December 2009 - 07:29 PM
You may be able to make something based on the VE master cylinder.
Posted 15 December 2009 - 02:32 AM
The underdash is usually used for concentric slave cylinder type setups inside the bellhousing
You simply need more volume to get the travel required unless you mod the slave down to a smaller size
The 600 includes the pedal too ... handy if you don't have one (unless its exchange)
Posted 15 December 2009 - 08:58 AM
Posted 15 December 2009 - 11:30 AM
#7 _nemo355v8_
Posted 04 March 2013 - 08:52 PM
Yep the malwoods is BA cylinder.
I did this
#8 _nemo355v8_
Posted 04 March 2013 - 08:58 PM
I used Wilwood universal master cylinder, shit load cheaper than a BA cylinder. Around $100 delivered from the usa and comes with remote resiviour
Posted 04 March 2013 - 11:17 PM
Posted 12 March 2013 - 10:14 PM
Here are my tips to install without removing the steering column:
- There are four bolts to the assembly, a bolt at the top [A]; two securing the master cylinder, one long bolt with socket head [b] at the pedal end and another hex headed bolt going through the far end [C]; and a large bolt which the pedal pivots on [D]. Bolts and nuts A to C are all 10mm socket or 5mm allen key.
- Before you install, put the unit on a bench.
- take bolts A and B out.
- Install and remove bolt B into its threaded nut several times to make it easier to wind in, you can't fit the assembly in easily with it attached so you need to do it with the pedal in position.
- Trim about 6mm off bolt B, otherwise it's too long to get a socket over the nut to tighten fully.
- Trim bolt D down to the nut face, otherwise it's too hard to squeeze past the steering column.
- Bench bleed the cylinder with both hoses attached, don't even try doing it in the car, it's on too steep an angle to get all the air out.
- Fit the rubber grommets to the hoses. Then plug the ends neatly so they can be pushed through the firewall.
- Now remove any loose carpet in the footwell.
- Remove the foot operated high beam light switch, two screws.
- Clear any loose wiring in the vicinity, you really have no room between the vertical section of metal the frame mounts to and the steering column.
- Now stretch your back as this is the uncomfortable bit.
- To install, the two points that bind the most on the under dash area is the big nut on bolt D and the top left of the frame. If you ordered the straight quick connector from Mal Woods, it is longer than ideal and when installed it will press hard against the firewall and be bent sharply at 90 degrees, still seems to work however.
- It will rub and foul on installation, carefully push it through keeping plenty of slack on the hoses connected. The ~90 degree connector on the low pressure side (to reservoir) is plastic and will break easily (I found out the hard way), not to mention cannot be replaced on its own probably meaning another master cylinder assembly(!)
- Once you have the assembly in position, I recommend installing bolt A with its aluminium spacer first and putting the end nut on loosely so you can install the aluminium spacer for bolt B without risk of the spacer falling out.
