What I wanna know fellas is
Can I steal the centre out of a 3.36 thats been welded , take off the 3.36 crown , then bolt back on a 3.9 crown , place it into housing with a 3.9 pinion?
If that makes sense...
Banjo pinion and crown?
_danny_
, Dec 15 2009 06:52 PM
6 replies to this topic
#1 _danny_
Posted 15 December 2009 - 06:52 PM
Posted 15 December 2009 - 07:34 PM
I would expect so, you want to end up with welded/locked 3.90
#3 _danny_
Posted 15 December 2009 - 07:37 PM
yup yup end result needed is a welded 3.9
Posted 15 December 2009 - 07:48 PM
Yes the 3.9 and 3.36 centres are definitely interchangeable
#5 _The Baron_
Posted 15 December 2009 - 08:12 PM
What?????
Are you saying you intend to use the same Pinion for both ratios?
The pinion must go with the matching ratio crown wheel.
Posted 15 December 2009 - 09:38 PM
no baron, he says he will use the 3.9 pinion.
Posted 15 December 2009 - 10:39 PM
For some reason I misread it the first time around as well. Yep sounds fine to me mate
