LC/LJ Steering Coupling/Flex Joint
37 replies to this topic
#1 _SableMet7/73_
_SableMet7/73_
Posted 19 December 2009 - 05:59 PM
Hi all
Havnt been around much of late, but found these pics in me camera that
I took when I last worked.
I was servicing a 86 Range Rover & noticed the steering coupling or flex joint
on this heap looked very similar to the 1s in our LCs & Js.
Attached File  100_1674.jpg   417.92K   64 downloads
Attached File  100_1675.jpg   373.73K   57 downloads
Measured across from bolt to bolt its 50mm, the same as my few old 1s & the 1 new
Metalux 1 I've got, so the Trana shaft coulpings should bolt up OK.
Its a little thicker (34mm) by about 9 to 10mm but the length of the flats machined
into the steering shaft & pinion shaft should allow it to fit, besides those
Nolathane ones are about that thick anyway.
I rang a Landrover/Rangerover place today & they're available at about $75, so probably
gonna be easier to find than a new genuine 1 or a good used original 1.
Cheers Jono
#2 _hutch_
_hutch_
Posted 19 December 2009 - 06:34 PM
i brought a nolathene one to put in mine
#3 _SableMet7/73_
_SableMet7/73_
Posted 19 December 2009 - 06:46 PM
Yeah I had 1 of those too hutch
but just didnt fell right, weather its a harder compound or what, dont know.
Just felt notchy as it flexed thru 90 degrees. Put a good old 1 back on & all was good.
Plus the bright red stands out like dogs balls which is why i hunted down some good old
1s & found a spanking new Metalux 1 also to put away in me spares.
J
#4 frash da bucket
frash da bucket
  • 1,890 posts
Posted 19 December 2009 - 10:44 PM
Hi i had a new old stock metalux too,
But when i fitted in the early ninety's,
It didn't last for very long,one corner,
Of the coupling broke of,i suppose it sat,
Around for too long,and the rubber desingerated,
So i had to fit a nolathene coupling it was red,
When i fitted in 1993 it changed colour,
From red to black,after about 8 years later.
I check it out regulary,i don't drive my torana,
Very much,its still the same condition when i fitted,
No cracks or any wearing at all.
Its the only non original part on my car.
#5 _SableMet7/73_
_SableMet7/73_
Posted 20 December 2009 - 03:38 PM
Didnt know they change colour frash, mine wasnt on the car
long enough.
Thanx for the warning about the Metalux 1 I've got, I'll keep
an eye on it when & if its all back together.
Bloke I spoke to about the R/Rover one said they were used on them
till they changed to a uni joint type arrangement in the late 80s.
So at least 10 to 15 years younger than the ones on our LC/Js.
After new years I'll see if I can find someone with 1 in stock &
take my Trana shaft couplings to check for fit & see if they're
old stock or still being made.
#6 frash da bucket
frash da bucket
  • 1,890 posts
Posted 20 December 2009 - 09:32 PM
Hi Sable,
I suppose it changed colour from the heat,
For all of those years,That metalux rubber,
Coulpling was brand new in the box it broke in 3 weeks,
But also keep eye on yours,when you fit it on.
You were saying about the range rover rubber coulpling too.
The metalux rubber coulpings were made in england also too,
And the pictures that you have provied,are very close to,
To the one's are are fitted on our LJ Torana's.
#7 dublinxu1
dublinxu1
  • 152 posts
  • Name:Brian
  • Car:73 Dublin Green XU-1
Posted 21 August 2010 - 09:37 AM
hi all,
i have been chasing a new coupling for my 73 XU-1 and wanted to keep the original
rubber type on and i found these on ebay from the UK.
thay are from a Vauxhall Viva HB and are NOS. a couple of these just landed today
and although i havent fitted one yet they look the goods. if anyone wants any measurements
or anything i am happy to help out.
heres the link
http://cgi.ebay.com....les_CarParts_SM
#8 _Ozzie Picker_
_Ozzie Picker_
Posted 21 August 2010 - 12:31 PM
hi guy,s
very interesting,
thanks for sharing and keep us informed in how your experiments work out as mine looks rooted as well.
#9 _BATHURST-32D_
_BATHURST-32D_
Posted 21 August 2010 - 05:03 PM
let me know if you need one craig i have a few really good ones here.
cheers gong
#10 S pack
  • 15,539 posts
Posted 21 August 2010 - 05:25 PM
Hey All
Just looking in the LC & LJ parts books. No different part no's listed for 4 and 6 cyl steering flexible couplings. Difference is for RH or LH drive. So looks like 4cyl and 6cyl LC & LJ used same coupling. Even appears the metal flanges, bolts and cotter pins are the same for both. Most likely the HB Viva steering column and coupling would have been used in the HB Torana as the cars were virtually identical and the HB Torana gear would have probably been carried through to the LC model. So if my guess is correct those couplings will be an exact fit for our Toranas.
Dave
Edited by S pack, 21 August 2010 - 05:25 PM.
#11 _Ozzie Picker_
_Ozzie Picker_
Posted 21 August 2010 - 08:36 PM
cheers gong
keep one for me my friend and one day we will catch up again,thanks for the offer.
cheers craig.
#12 S pack
  • 15,539 posts
Posted 21 August 2010 - 10:43 PM
G/day bsbrians
The following pic is of a NOS LC/LJ coupling. Looks to me like it is identical to the HB Viva part.
As you can see it has the word Patent across the bottom and Metalastik across the top. On the left hand side it has the number 21/940 and on the right hand side it has an X above the number 7. How does that compare to the HB Viva couplings you've bought.
Dave
#13 dublinxu1
dublinxu1
  • 152 posts
  • Name:Brian
Posted 22 August 2010 - 09:48 AM
S pack,
they have Patent across the bottom and Metalastik across the top,on the left hand side it has the number 21/940
but on the right hand side where the X is all three i bought have different numbers. 6,13 and 15. my guess is mould numbers?
apart from that they look exactly the same as yours.
#14 S pack
  • 15,539 posts
Posted 22 August 2010 - 10:41 AM
S pack,
Perfect, I reckon that's enough to call it an exact match. I have two others one has a 12 the other has a 15.
#15 enderwigginau
enderwigginau
    Admin Wrangler
  • 2,000,527 posts
  • Name:Grant
  • Car:76 LX Sedan, 4 seater
Posted 23 August 2010 - 01:19 PM
sstorana should by the whole crate of them for us :D
Then anytime someone want to buy one.......
#16 71xu1
71xu1
    Dave
  • 1,265 posts
  • Car:LC GTR XU1
Posted 23 August 2010 - 03:08 PM
Rare Parts in Welshpool do the black ones a per original. Give Todd a call.
#17 _SableMet7/73_
_SableMet7/73_
Posted 23 August 2010 - 05:52 PM
Thats who I got the Metalastic one from
Havnt found a Range Rover 1 in stock to check yet
Was told a while ago that early Capri's had a similar coupling too but
havnt seen one
Jono
#18 _gsh253_
_gsh253_
Posted 09 December 2013 - 06:01 PM
So do the couplings from rare's fit
or do we get them elsewhere.
Vic
#19 kiwi-lilj
kiwi-lilj
  • 1,420 posts
  • Name:Blair
  • Car:LIL J
Posted 09 December 2013 - 06:09 PM
So do the couplings from rare's fitor do we get them elsewhere.Vic
I got one from rares and it fit very well. It was so much nicer to drive once I removed that red POS.
#20 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 09 December 2013 - 07:35 PM
Hi
If you are not in any hurry, you can get the original from UK ebay for less than $20 Australian dollars plus postage. Search for Vauxhall flexible steering coupling.
Bazza
#21 _mikecatts_
_mikecatts_
Posted 10 December 2013 - 04:50 AM
orded mine x 4
http://www.ebay.co.u...=item43c2c382d5
#22 limo
limo
  • 2,672 posts
Posted 10 December 2013 - 05:26 PM
I bought 4 Bedford ( same as Torana), with postage about $65  I think ( bushes and pedal rubbers and other Bedford bits), here in 5 days
#23 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 14 December 2013 - 12:06 AM
Thanks for the tip there Bazza and Mike I just brought one too from the same seller. That's a decent $120 odd saving.
I try to buy local as much as possible but at times like this it's hard to justify such a large margn.
#24 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 14 December 2013 - 09:46 AM
Hi
No probs. We have been getting ripped by people 'in the know' about these for years. These couplings are identical to the original, in fact, they are made by the same original manufacturer "Metalastic". Holden must have imported them direct way back when. I don't know why Rares bothered to make their own when these are still being made. Before Rares made theirs, private importers were charging $185 after buying them in the UK for around $20. They are still asking around $160 for the same thing.
Bazza
#25 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 14 December 2013 - 09:35 PM
Hmmm that's interesting thanks Bazza
Steve
