LC Engine Mounts
#1 _CraigA_
Posted 30 December 2009 - 06:16 PM
And which one goes at the front and which one at the back of the lower mount?
Went to fit the shifter back into my car today and the thing wouldn't fit. Was hitting on the drivers side floor so it looks like the engine isn't aligned in the car properly.
Thought I marked them when removed but must have made a mistake.
Can someone let me know.
Thanks.
Posted 30 December 2009 - 06:28 PM
rhs sits in front of the engine bracket.oilpump side gives clearance for bolts
lhs is behind the engine bracket
Edited by limo, 30 December 2009 - 06:30 PM.
#3 _CraigA_
Posted 30 December 2009 - 06:50 PM
Another question. There is a spacer block (about 1" thick) fitted between the gearbox mount and gearbox crossmember. Is this correct for M20?
Posted 30 December 2009 - 07:10 PM
there is a plate that goes under the crossmember between it and the bolt heads but it is only about 3/8" thick
#5 _CraigA_
Posted 30 December 2009 - 08:31 PM
In the LJ one it shows the spacers fitted to the outer bolts of the cross member and a load spreader fitted to the centre. This is the three speed manual.
The M20 diagram shows the large centre spacer, the outer spacers and a load spreader. This is the set up I have but I am missing the load spreader plate.
Could someone with a LC/LJ with 6cyl and M20/21 please confirm that the above picture is what they are using.
Thanks.
Edited by CraigA, 30 December 2009 - 08:44 PM.
Posted 30 December 2009 - 09:11 PM
The middle one is correct for the Aussie 4 Speed. The bottom one is left hand drive export model ie Opel. Look at the mounting block in the 1st and last picture.
Bazza
Posted 31 December 2009 - 05:48 AM
Correct!!Hi
Bazza
This is the problem of using the term 'M20'. Both the Aussie 4-speed & the Opel box are called M20.
Dr Terry
#8 _CraigA_
Posted 31 December 2009 - 08:28 AM
#9 _oz772_
Posted 31 December 2009 - 01:44 PM
Thanks guys. The 1" thick spacer must be left over from when my XU1 had the Opel in it.
That is correct. The thick spacer is needed with the opel box. This photo is of the spacer kit needed for the opel.
2976_1.jpg 11.36K 10 downloads
#10 _CraigA_
Posted 31 December 2009 - 11:29 PM
Posted 22 June 2020 - 09:49 PM
So I was digging around up in the mezzanine today and found that I have 2 crossmembers.
I know which one is original to my car but on the other one, the plane where the g/box mount bolts on is about 20 - 25mm lower?
Would this be Opel?
Posted 22 June 2020 - 10:08 PM
Would this be Opel?
LC and 1st type LJ 6cyl transmission support members were the same for Opel M20, Aussie M20, M15 three speed and M40 Tri-matic. just one extra spacer and the actual rubber mount differed for Opel.
Edited by S pack, 22 June 2020 - 10:13 PM.
Posted 22 June 2020 - 10:21 PM
So....……………..What have I got?
Posted 22 June 2020 - 10:47 PM
#15 _oz772_
Posted 23 June 2020 - 09:35 AM
Sounds like it might be one of the very early crossmembers. Is it a sort of shallow V shape? Seems they were used for the first few months of production before they reverted to using the same crossmember for all versions (3 spd, 4 spd, auto) with just different mounting spacers.
Posted 24 June 2020 - 12:28 PM
It's pretty much the same shape as my original 72 LJ one except the plane where the g/box mount goes is 6mm lower.
Posted 24 June 2020 - 06:42 PM
