TRIPLE CARBYS
Posted 28 February 2010 - 10:10 AM
one set are all 128D plus the one brass tag thats left on them the number is 3161 and 028
the other set one carby has 128A the other two are 128B and the original manifold number with this is 2815923 dont know if that helps. calling the gong or bazza any info would be great cheers.G
Posted 28 February 2010 - 12:37 PM
128d never seen one before so i wont comment on it
Posted 28 February 2010 - 02:06 PM
Thanks johnno i thought the 128a and bs were lc xu1s but i got no idea of these 128d any body else shed some light on these they are both on original holden manifolds as well.G128a and 128b LC xu-1
Posted 01 March 2010 - 02:31 PM
Are you sure about that part no. on the manifold, the LC parts catalogue lists the XU1 inlet manifiold as being Pt No. 2815922.
Regards
Dave
Posted 01 March 2010 - 05:23 PM
Hi dave you could be right there that much paint on this manifold its hard to readHi Glacier 73
Regards
Dave
it maybe 2815922 will clean up the manifold a bit more see if your right.
i have two original manifolds one is stamped HOLDEN the other has GMH on it is one early xu1 and the other later maybe.
Posted 02 March 2010 - 01:34 AM
I don't know when the change came about with the branding but I assume the GMH branded manifold is the earlier one and the holden branded one is later. LJ Xu1 manifolds that I have seen all had holden on them. I remember that my dads' FC grey motor single carb manifold was branded GMH.
Hopefully someone else out there might have factual info on this change.
Dave.
Posted 05 March 2010 - 08:28 PM
#8 _1973bathxu1_
Posted 05 March 2010 - 09:04 PM
i hope this helps u
regards aldo
Posted 06 March 2010 - 12:32 PM
Still trying to find info on these carbys the 128D strombergs has any one come across these before cheers G.
hey Glacier
ebay item 120537912553 are a nice set of 150s sitting on $1060 with 23 hours to go
i emailed this dude and he states the carbs are 128A, 128B and 128D so thats the second
one i have seen in a week(including yours)considering that all xu-1 stamped carbs(LC/LJ)
can only be found in australia only, i wonder if the 128d is a australian only carb as well
are there any visible difference on the carb bodies??? eg extra screws??
i think more research is needed here
cheers johnno
Edited by meanmachine72, 06 March 2010 - 12:33 PM.
Posted 06 March 2010 - 09:34 PM
tag i thought that tag number 3161/028 might have helped
hey johnno they look the same as the 128a cheers Gene.
Posted 07 March 2010 - 09:09 AM
Looked up my stromberg book, the tag number 3161 was allocated to the 1967/1971 Singer Gazelle 1500cc and 1725cc CI head
with 150CDS carb.
Hope this helps,
Dave
Posted 07 March 2010 - 12:33 PM
Thanks heaps dave so these singer gazelle surely did'nt run triple stromies some one must have slapped them on this xu1 manifold i have mmmmm interesting G.Hey Glacier73
with 150CDS carb.
Hope this helps,
Dave
Posted 07 March 2010 - 11:11 PM
It appears the Singer Gazelle ran a single 150CDS Stromberg with 6Q needle, .090 jet and red coded air valve spring.
The Gazelle was an upmarket Hillman Minx. Have since found the Minx had the exact same carb and tag number. I am assuming the Gazelle and/or the Minx was exported to OZ but don't know for sure.
Do the 128a & 128b XU1 carbs look identical and I mean identical to the 128d carb or are there any differences no matter how small. Also which manifold are the 128d's on, the one branded GMH or Holden. Another suggestion is remove the float bowl from a 128a and a 128d carb and see what the production year number and month clock can tell you. You will find it in the fuel bowl area of the carby body.
I am guessing (very wild at that) maybe the first ever batch of 150CDS carbs for the LC XU1 that Zenith supplied were the 128d's and they just changed the needles, springs, throttle arms etc to suit the XU1.
Looking at the book it appears that every individual combination of carby body, needle, jet, air valve spring etc etc was allocated a different tag number and possibly a different code stamped into the air cleaner mounting flange (my book doesn't give those codes).
Dave.
Posted 07 March 2010 - 11:40 PM
Hi dave thats great info you got there i will take another look at these carbys and see if there is a difference and the 128d are on the manifold stamped holden.Gene.G/day Gene,
Dave.
Posted 17 April 2010 - 09:45 PM
128
3163F
Any ideas what the tag means?
Posted 07 May 2010 - 02:44 PM
Have a set with 128 only on them and one brass tag left with -
128
3163F
[/quote
checked mine today front carb B128,middle E128,rear is 128,they all look identicle except the fuel inlet pipe on the rear is bent at 90degrees to miss all the linkage brackets etc onthe firewall
#17 _rogered_
Posted 07 May 2010 - 03:13 PM
all carbs stamped 128 on the air filter face
brass tags (1 missing)
first reads 3257 035 and has a big A stamped into it
second tag 3257 028 and again with a big A
mines a 10 71 car and would i be surprised if these were not the originals, but admit to not knowing much about carb numbers.
Posted 07 May 2010 - 06:21 PM
128
3163F
The brass tag coded 3163F is for the front carb of a twin 150CDS carb set up for a 1967/1971 Humber Sceptre 1725cc.
The tag from the rear carb would be coded 3163R.
1970/71 LC XU1 carb tags should be coded either 3380 or 3381.
Posted 07 May 2010 - 06:27 PM
just had a look at mine if it helps
3257 is the code for Vauxhaull Viva 1159cc engine.
#20 _rogered_
Posted 08 May 2010 - 06:39 AM
#21 _1973bathxu1_
Posted 11 May 2010 - 06:18 PM
i checked my 9/71 xu1 to make sure and they read
CARBY no 1 3257 A CARBY no 2 3257 B CARBY NO 3 3257 A
I HOPE THIS HELPS U
REGARDS ALDO
#22 _rogered_
Posted 11 May 2010 - 06:44 PM
thats a relief.
#23
Posted 12 May 2010 - 12:24 AM
Sorry if I caused you some stress.
The carby info I provided was quoted from my CD Stromberg repair manual.
Obviously the book is not perfectly correct.
Dave.
#24 _rogered_
Posted 12 May 2010 - 06:16 AM
Im curious now as to the numbering system on these tags, and might look deeper into it.
#25 _BATHURST-32D_
Posted 13 May 2010 - 06:42 PM
any help from you or anyone with original ck car and engine bits would be good.
cheers gong
