How do i remove banjo axles?
#1 _TORRI-1_
Posted 05 March 2010 - 05:14 PM
I want to run HQ pattern wheels on the rear of my LH (standard banjo), there's a shop here that will redrill my axles and drums, my question is before i start taking things apart, is it pretty straight forward?, anything i should/shouldn't do?
Basically i just remove the wheels, drums, few other bolts and the axles should slide out yeah?
#2 _torana_umunga74_
Posted 05 March 2010 - 05:23 PM
Posted 05 March 2010 - 05:48 PM
#4 _torana_umunga74_
Posted 05 March 2010 - 05:49 PM
#5 _TORRI-1_
Posted 05 March 2010 - 06:05 PM
Any tips on putting it all back together?
Posted 05 March 2010 - 08:59 PM
Don't forget the backing plateAny tips on putting it all back together?
#7 _TORRI-1_
Posted 06 April 2010 - 06:23 PM
Cheers!
Posted 06 April 2010 - 06:45 PM
Doesn't hurt to put a bit of grease on the wheel bearings but really as long as you give everything a squirt of oil as you put it together, and roll around a low speed a bit before driving normally, I don't see why there would be any problem.
Posted 22 October 2017 - 03:49 PM
hi all
i have a Banjo Axle that is stuck and will not budge
non lsd fine spline
the 4 retaining bolts have been removed
i have tried the reverse drum method to pull the axle out
have also tried wrapping a chain around the axle flange to try a snatch it out..
any advice
Posted 22 October 2017 - 05:32 PM
Soke it in weezel piss and let is sit over night. Then attach the wheel loosely and try and pull it off that way using the wheel as a puller.
Edited by Redslur, 22 October 2017 - 05:32 PM.
Posted 22 October 2017 - 06:35 PM
On sticky ones I have put the wheel back on and used a sledgie to remove .... make sure its not a wheel you like
Posted 22 October 2017 - 08:40 PM
Posted 23 October 2017 - 04:45 AM
I put the cog on the bolt and then the threaded part of the bolt thru the axle flange, washer behind and put the nut on. Then bust a nut sliding the cog with force to pull out the axle.
I'm a big guy and over the years I've encountered some bloody tough axles to pull with there being nothing wrong with the centre. Just persist, brute force will prevail!
