G/day All.
Read a post recently about someone needing parts to repair their LJ wiper washer pump but I can't find the thread.
So thought I'd start one on converting the pump to electric.
Here's one I did earlier, 25 years earlier.
Bugger, what happened to all my Photobucket pics?
This pump/switch now contains a push type switch which operates the windscreen washer bottle & pump motor from a HX Holden.
Think I've finally got this photobucket thing worked out. Sorry the pics are a bit out of focus, my camera doesn't do good close ups.
Here is the pump switch and you can see the switch spade connectors.
Had to rebate the end plate 1.2mm with the Dremel to accommodate the switch.
I used a wiper switch from a Kingswood in my LC to operate the washer bottle pump. The switch came from a HK-G model Kingswood, so the switch doesn't look out of place at all. The only mods needed for this is to run two wires from under the dash to the washer bottle.
G/day Ben
Interesting. do you have any pics of the HT-G wiper washer switch?
