Speedo cable
8 replies to this topic
#1 _Bart15_
_Bart15_
Posted 01 May 2010 - 12:04 PM
Hi all
I need to get access to the back of an LH SLR instrument cluster. The only thing I am stuck on is the the speedo cable, how does it come off the back of the cluster? I don't want to force it and cause it to break!
#2 _The Baron_
_The Baron_
Posted 01 May 2010 - 03:34 PM
Hi all
When unscrewed, can just get your hand around the back to squeeze the plactic fitting at the very top of the speedo cable. It should just unclip.
NO NOT FORCE IT.
#3 to fly
to fly
  • 335 posts
Posted 02 May 2010 - 01:27 PM
Yep as above, careful the clip will bust very easily so take your time, plan B,try disconnecting from the gearbox end, only one bolt and feed a bit of cable thru the firewall behind the dash and leave the speedo cable in the cluster,
#4 Heath
  • 18,314 posts
Posted 02 May 2010 - 03:48 PM
The Baron's description isn't exactly how I'd put it. Can't hurt to have an extra view...
The clip mechanism is on the end of the cable where it touches the cluster. The end of the clip that your finger will find hangs out one side of the cable, doesn't go around the whole way. This little tag should be pushed against the sheath of the cable (yes, push it towards the centre of the cable). This will unclip it but not detatch it, you will need to jiggle it very lightly (in an axial movement, not sideways) for it to slip out of the back of the cluster.
Kinda annoying because you can't see shit and it's tricky to move around a lot up there.
#5 Chips
Chips
  • 80 posts
  • Car:LX hatchback
Posted 30 September 2019 - 05:19 PM
this was useful.
i don't know if it's gone back on properly
#6 Chips
Chips
  • 80 posts
  • Car:LX hatchback
Posted 10 October 2019 - 05:00 PM
any experience on how to reconnect?
I put it back and it seems to work on the driveway. haven't got onto open road yet.
but it seemed loose-ish.
totally blind and not much room to play with there squeezing in behind dash!
#7 Statler
  • 6,282 posts
Posted 10 October 2019 - 05:18 PM
There's just enough room to push it back on from under the dash.
If it's working but the needle 'bounces' it needs to go in a poofteenth more.
I've found it easier to fit by pulling the centre out about 10mm & sliding it into the cluster first , then pushing the sleeve on.
#8 Chips
Chips
  • 80 posts
  • Car:LX hatchback
Posted 11 October 2019 - 02:39 PM
thanks. that's exactly was my concern and experience.
that loose centre bit seemed to have come out a bit more out when I went to reconnect and then when fiddling around trying to refit it felt like it had gone back the other way and wasn't maybe in.
I was putting that cable bit in first then trying to somehow hold it there and get that plastic lock over it.
and now now not sure the plastic locked on properly but don't want to touch it in case it's ok and I break it trying to do something that doesn't need doing.
#9 koalasprint
koalasprint
  • 295 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 11 October 2019 - 02:49 PM
Mine is hard to do too. As above, pull the inner out a tad and rotate it as you push the cluster/dash towards the cable. Itcan also help to have the cable unplugged from the gearbox if that is convenient to do. I think the female socket on the speedo is flogged out on mine. I put a dob of epoxy putty on the speedo entry hole and that does the trick, but it is a last resort.
