Last time I was using a supra 5 speed but as this time I'm going auto and using a trimatic.
I'm just wondering as to where I would hook up the vacuum module to? Before the turbo where there is constant vacuum (think this is correct?). Or after the turbo where vacuum would be present at low loads and positive pressure at full load?
As my understanding is that the vacuum module is used to up shift gears when there is vacuum. This leads me to believe I should hook it up after the turbo or to the inlet manifold?
Any can confirm or deny this?
Thanks.
Edited by deviot, 03 June 2010 - 02:18 PM.
