chrome trim repair
#1 _V6 UC_
Posted 16 July 2010 - 09:00 PM
#2 _nial8r_
Posted 17 July 2010 - 07:58 AM
#3 _V6 UC_
Posted 19 July 2010 - 06:05 PM
Posted 19 July 2010 - 08:35 PM
autosol wont be enough, are they made of ali? they look like they are, if so i should be able sand out the scratches and repolish, if only i had a spare to try by i dont so just was after u guys opinions
G/day V6 UC
What sort of chrome trims are you talking about??? Can you do a test on the back of the trim where it won't be seen???
Pics could be handy.
#5 _V6 UC_
Posted 19 July 2010 - 09:18 PM
#6 _nial8r_
Posted 20 July 2010 - 08:11 AM
#7 _Woodsy_
Posted 20 July 2010 - 09:20 AM
#8 _CraigA_
Posted 20 July 2010 - 09:34 AM
If its chrome plastic then you will need to get them re-done.
If its stainless then 2000 wet and dry (rubbed wet along the scratch) will work then on the buff with some compound. They'll come up perfectly.
Posted 20 July 2010 - 02:43 PM
Are they chrome or stainless on a UC?
UC are polished alloy with a protective coating of clear anodising.
#10 _CraigA_
Posted 20 July 2010 - 03:29 PM
OK. Then its going to be impossible to repair to factory quality without polishing and re-anodising.
Posted 20 July 2010 - 05:07 PM
#12 _V6 UC_
Posted 20 July 2010 - 08:56 PM
Posted 21 July 2010 - 01:01 PM
When I made up my shifter knob, collet and horn button out of machine grade ally, it was clear anodized and that process turned it a bit more pale and satin-ish finish rather than a high gloss look, but for all intents and purposes you probably won't notice the difference. I'm not sure, depends on the particular material
Posted 21 July 2010 - 05:37 PM
I'm considering doing that to my aluminum molding but not sure if anyone has tried that coating for exterior trim.
I can't seem to find any anodizers that can achieve an original finish.
Posted 21 July 2010 - 06:35 PM
Anodizing is just sitting a part in a few baths, can the look of it really vary that much if the material is the same as original?
#16 _V6 UC_
Posted 21 July 2010 - 07:43 PM
Thats a pretty good idea ando, didnt think of that, iv heard that stuff actually doesnt look too bad, i guess it could be used as a last resort if the polishing turns to shit. Im not too familiar with anodising apart for sending stuff off at work and it coming back a gold colour, must be a different process. does any1 have a spare piece i could buy off them to try instead of possibly ruining mine for the car.?
Posted 21 July 2010 - 07:57 PM
I reckon the 'chrome paint' looks great but it ain't chrome - unless you did everything with that paint, I don't think it would look good. That's just my 2c
Posted 22 July 2010 - 06:10 AM
What they told me is they have to do is firstly is de-anodize the factory coating in a bath.
You take the item back & take the dents & scratches out. Return the molding & they will bath the item for final coating.
The problem is they can't replicate the factory finish. They can only achieve a duller finish which doesn't suit me.
So that's where I'm at the moment until I find a better solution.
I haven't done a sample either with the chrome paint idea but since this subject has come up, I'm open to solutions.
Posted 22 July 2010 - 10:43 AM
Posted 08 April 2014 - 06:07 PM
Old thread, but I'm keen to see if anyone has gone down the path of refurbishing the alloy moulds around the LX windows. Mine could do with a freshen up...it appears as though they have a clear coat from the factory - i'm not sure that this is the same thing as anodising? Anyone shed some further light?
#21
Posted 08 April 2014 - 06:51 PM
Whether it's stainless or alloy the procedure is the same, knock out any dings, file flat, sand the whole surface working your way through the various grits down to 2000 grit and then polish. If you only do a small section it won't match the rest.
The original finish on our alloy head and taillight surrounds is apparently referred to as
"bright silver ", not just a clear anodising over a polished surface.
I used the above method on all my stainless window and gutter moulds and they now look like new or better.
JD
#22
Posted 08 April 2014 - 07:24 PM
Without sorry
#23
Posted 08 April 2014 - 07:31 PM
Thinners and a rag, Gene.
#24
Posted 08 April 2014 - 08:40 PM
#25
Posted 09 April 2014 - 05:31 AM
JD
