Holden 202 Head porting & engine dyno
5 replies to this topic
#1 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 22 August 2010 - 06:14 PM
Hi ALl
Curious Who has used who for head porting? Up till now ive always had a mate do mine but my new alloy head i want done on a flow bench, Was think Hans Hi-port cylinder heads or bullet Any other suggestions??
also Engine Dyno Who in melb has an engine dyno that wil run up a holden 202?:?
#2 biga064
biga064
  • 195 posts
  • Name:Adam
  • Car:EH Holden
Posted 22 August 2010 - 08:13 PM
Hi ALl
Rod Rainford Advanced engine dynamics the best !!!
#3 _coupe202_
_coupe202_
Posted 22 August 2010 - 09:25 PM
For head porting I would recommend Speedworks in Ringwood and for engine dyno I would use Gene Cook in Tullamarine good operator just had my engine dynoed there.
Edited by coupe202, 22 August 2010 - 09:25 PM.
#4 Stedz_lc
Stedz_lc
  • 1,144 posts
Posted 23 August 2010 - 07:47 AM
What did the dyno cost you for how many hours?
I had thought of tony used him in the past might have a chat with him!
#5 turbotrana
turbotrana
  • 155 posts
Posted 26 August 2010 - 01:39 AM
I ported my Hold6 alloy head around 15 years ago and even now after doing a few more heads would not alter what I did back then.
The basic port casting is fine, you just need to smoothen it all out, narrow down the valve boss, leave the short side radius pretty much as it is except smoothen it out.
I used a Vk fuel injection manifold and took alot out of one side of the runners to match the cross section of the head entrance. This is where the biggest
restriction is if using a VK injection manifold.
#6 _coupe202_
_coupe202_
Posted 28 August 2010 - 03:20 PM
Cost of dyno from memory was between $600 to $800, it works out about $110 an hour.
