BW78 LSD or lokka? which one?
_@milco@_
Posted 24 August 2010 - 11:52 AM
engine is a 330 stroker 286 or 288 cam and turbo 350 in a lx torana
Posted 24 August 2010 - 02:43 PM
I wore out a reasonably tight LSD centre in around 6 months with a couple of drag racing stints and an off street burnout, the Lokka has been going strong ever since but it does require a little change in driving style.
_@milco@_
Posted 24 August 2010 - 04:21 PM
Posted 24 August 2010 - 04:26 PM
Posted 24 August 2010 - 05:32 PM
You should go for a test drive in a car with a Lokka before making a decision. You may find the noise and locking action is not worth the extra traction.
If money is not a problem then have a look at the KAAZ. I think they are available for the BW78
Posted 24 August 2010 - 09:01 PM
_@milco@_
Posted 24 August 2010 - 10:24 PM
only problem is my diff is going to get built next week and i called the lokka manufacture/supplier and they dont have any left for a BW78 and will not be getting any for 3-4 weeks...... where as i can get a New lsd put in straight away........ mmmmmmmmmmm dont know what to do....
_youngy_11_
Posted 25 August 2010 - 06:57 AM
Youngy
Posted 25 August 2010 - 07:33 AM
Posted 25 August 2010 - 11:33 AM
The Lokka with provide 100% torque to both wheels.
The KAAZ will go close to 100% torque to both wheels. In a straight line the torque is used to increase the clamping pressure on the KAAZ clutches.
Posted 25 August 2010 - 12:05 PM
Posted 25 August 2010 - 02:20 PM
The Detroit Truetrac is a good street diff however it will only provide a maximum of 75% torque to the other wheel.
Where do these figures come from?
Posted 25 August 2010 - 03:28 PM
This 3MB pdf test results document shows a torque bias of around 3.0 for the Truetrac.
The Lokka is a locking differential which by definition delivers 100%.
The KAAZ LSD figure is an estimate. In a straight line the LSD clutch pressure is proportional to the amount of torque applied to both wheels. In theory the KAAZ should not slip under load and therefore effectively become a locking diff in a straight line.
This webpage has an interesting chart explaining some of the different diff options for 4WD applications.
Edited by ls2lxhatch, 25 August 2010 - 03:30 PM.
_youngy_11_
Posted 25 August 2010 - 03:35 PM
Yes the original supplier put me onto a detroit 'NoSpin' but I did get a quote from another supplier for a Detroit Trutrac for $1000. I have not got one yet as have been spending money elsewhere on the car.
I have the email at work and will get it on Friday.
Youngy
_youngy_11_
Posted 31 August 2010 - 10:22 AM
I spoke to Rick.
If you find a cheaper quote let me know.
Also go and buy one get it fitted and tell us all how it goes
_L32M20_
Posted 10 May 2012 - 09:03 PM
