LJ Torana Radio
#1 _Steven72_
Posted 08 September 2010 - 09:36 PM
#2 _tail light_
Posted 08 September 2010 - 10:00 PM
thanks in advance
Posted 08 September 2010 - 11:40 PM
i would also like to know what the original radio options were for 1972 xu1 and may be a picture if some body has one of the options
thanks in advance
Hi all
The available radios were "Air Chief" and came in 13 transistor Push Button, 11 transistor Push Button or Manual tuning, or 8 transistor Manual tuning only. When looking for an original radio for the LJ, be sure that you get the one with rounded corners and be sure that the filler panel comes with it. A lot of radios on eBay are from HQs, (they have square corners on the facia) but are sold as suiting LJ Torana. The actual radios are the same but the facia is different and will not fit correctly or cleanly.
Bazza
#4 _tail light_
Posted 09 September 2010 - 08:35 AM
thanks in advance
Hi all
Bazza
thanks bazza, thats exactly what i needed to know, now i can search for the correct radio,
mick
Posted 21 September 2018 - 06:53 PM
Any installation instruction diagrams would be good.
Posted 30 September 2018 - 08:39 PM
Posted 30 September 2018 - 09:22 PM
Hi James I've just seen you post, here's some pics of my radio bracket. Probably too late for you now!
Posted 01 October 2018 - 07:02 AM
Thanks for your pictures. I knew that I'd seen one of those radio's with the rear bracket although they seem quite rare.
It turns out that I've used the same screw hole in the radio but on the drivers side instead.
I assume that you're bracket bolts onto one of the two elongated holes in the dash just above the cigarette lighter, is that correct?
James D
Posted 01 October 2018 - 09:02 AM
Hi James,
Its been so long since I pulled the car apart I couldn't tell you where the bracket bolts in, I can suss it out on the weekend.
I have a spare original bracket that's all plated up. If you're interested in it PM me.
Here's the original fitting instructions, this might help also
Posted 01 October 2018 - 10:45 AM
Thanks for the pictures and information, that's exactly what I was looking for.
Just for reference the thread size required for the bolts that fasten the front of the radio at the bottom to the dash panel they're a 3/16" thread about 3/4" long should be sufficient. I need to order some hex head ones as my local fastener shop only had them with a Phillips head or Allen key head but access is very awkward to tighten or undo these screws with a slot or Phillips head screw.
