I'm tossing up what to bolt up behind my new motor.
Currently I'm running a Trimatic with a 2500 Stall... It seems like a pretty tight box, shifts well and all. But i'm worried that it won't hold up to a 400hp+ 355.
So I'm now thinking about other options. Here is a list i've been thinking in my head of each box.
Trimatic - (Beef mine up, or buy a better one)
- Can keep my tailshaft, crossmember etc. Easy fit
- Just need to have block re-drilled to suit Trimatic Pattern
- Fairly cheap to come across, and seem to handle power easier
- No Need to re-drill the block
- Need to buy new Crossmember, Tailshaft, Stall, shifter brackets etc
- Overdrive! Would be great for cruising an could mean i could get some 4.11's in the future.
- Heard they can't withstand heaps of horsepower
- Bit of Tunnel Massaging required?
- Enjoy driving a manual again!!
- Need to buy new Crossmember, Tailshaft, and everything associated with the manual conversion.
- Lots more hassles getting the clutch etc all working perfectly
- Not sure if the pipes i already bought will fit or not.
