Are T5's different?
15 replies to this topic
#1 _j.e.d._
_j.e.d._
Posted 04 October 2010 - 02:35 PM
Silly question but hey...
Is the T5 manual that fits up to a V6 different than the V8? Stronger, weaker, different shaft?..
Its just that there's a heck of a lot for sale for the V6 ones, but not the V8 ones so wondering if I can save some money there, otherwise I'll change the shaft on my M20 (orig. 6cyl) to suit the injected 5L I'l going to run.
Cheers,
Jase
#2 _aussie4speeds_
_aussie4speeds_
Posted 04 October 2010 - 02:56 PM
the v6 t5 has a difrent torque rating and the input shaft is too long to go into a v8 hey check out what we do at our web site here is the link http://freewebs.com/aussie4speeds/
we make m21 race boxes able to handle up to 200 kw using the xu1 ratio we also recondition shifters and linkages we have standard modified and the race aplications
all made to order give us a call a m21 is a far easier conversion than what a t5 to put in to a torana and my M21 race boxes are alot stronger than a t5 5 speed box .
#3 76lxhatch
  • 7,222 posts
Posted 04 October 2010 - 09:39 PM
Same basic box, different length input shaft as above (longer for V6 which makes life difficult), different ratios. Apparently the Ford T5s are easier to get hold of and both the input shaft length and shifter position are better suited to conversions for earlier cars.
#4 _rob350hatch_
_rob350hatch_
Posted 05 October 2010 - 07:49 AM
well tell em the price son
ive got stuck here with 2 v6 t5s not knowing but found out the hard way.
i have a t5 out of an eb xr8 will this bolt up to a 1985/6 302 out of a mustang?
Edited by rob350hatch, 05 October 2010 - 07:50 AM.
#5 gtrboyy
gtrboyy
  • 3,241 posts
Posted 05 October 2010 - 02:41 PM
Input shaft is longer needing to be shortened & I think 1st gear is heaps shorter,nearly useless for a decent v8.
A mate got ripped off on a reco t5 box years ago after a workshop swapped his v8 t5 for a v6 box.
#6 76lxhatch
  • 7,222 posts
Posted 05 October 2010 - 04:35 PM
First is 3.25:1, would still be fine for a cruiser with 3.08:1 or taller diff but not so useful for a quick car
#7 _rob350hatch_
_rob350hatch_
Posted 05 October 2010 - 05:48 PM
isnt an eb xr8 a windsor as well? i know input shaft is an issue going to cleveland though
#8 _aussie4speeds_
_aussie4speeds_
Posted 05 October 2010 - 05:49 PM
you can shoten the v6 t5 length to a ford length and use it in a torana get a crs bellhousing and it will fit in nice a lttle bit of floor cutting and welding but no biggie i recondition those boxes as well as my 4 speeds
#9 _rob350hatch_
_rob350hatch_
Posted 05 October 2010 - 06:25 PM
so my 2 vn v6 boxes arent a total waste .theyll go behind a 253 or 308?
and what about the ebxr8 t5 will it fit behind the 85/86 mustang 302 windsor?
also your 4 speeds you say 200kw but tell us some torque figures because thats whats going to break them.
Edited by rob350hatch, 05 October 2010 - 06:29 PM.
#10 gtrboyy
gtrboyy
  • 3,241 posts
Posted 06 October 2010 - 05:01 AM
V6 box will be fine behind a stocker v8 with tall gears,just don't see the point going with the v6 box when you can get more suitable one from a ford.
rob -Dellows should have the info in their catologue,maybe even on their website with measurements/info on how to identify which box is which & what they fit etc.
#11 _rob350hatch_
_rob350hatch_
Posted 06 October 2010 - 03:47 PM
yeah i already have the eb box/ mild 302 windsor. its for my xw race car.the v6 boxs were just aquired damage along the way. im trying to avoid the toploader route.what was your thinking on the more suitable box from ford?i cant think of any ?
#12 _nemo355v8_
_nemo355v8_
Posted 15 October 2010 - 07:22 PM
Not a waste at all. find a input shaft out of a ed or later ford box. All commy v6 t5s use a 3.25 first gear.
EA/EB boxes use 3.5 first gear, ED to EL use the same box as commodore just different input shaft lenght, easy swap over. to make sure you get the right input shaft take out your v6 one and count the teeth on the input shaft. been doing the reasearch because i broke the ford t5 behind my 355 and found it hard to get another ford one but there were plenty of v6 ones going cheap. did find a ford one in the end thou
early t5s are rated at 265 foot pound of torque up to 1992 later than that they rated 300 foot pound
#13 _nemo355v8_
_nemo355v8_
Posted 15 October 2010 - 07:55 PM
http://www.jegs.com/...343713/10002/-1
Upgrade your T5 to 600 foot pound and 500 HP. leave the top loader in the dark ages.
input shaft and gears $1295 and main shaft $355.
#14 _Quagmire_
_Quagmire_
Posted 15 October 2010 - 11:27 PM
send me a pm reminding me to ask my mate on sunday about this and upgrades as he rebuilds all his ford t5's
don't see how it won't bolt up as the windors where a crate motor imported from the states and fitted in aust so to my knowledge the only thing different would be the ratios
also for your imformation there are only about 7 different bell housing patterns in use around the world in car engine desgin
#15 76lxhatch
  • 7,222 posts
Posted 16 October 2010 - 07:52 AM
There are a couple of different T5 main housings though:
#16 _Quagmire_
_Quagmire_
Posted 16 October 2010 - 08:04 AM
he he seek and you shall find!
always someone out there smarter/has more info than me out there Posted Image
thanks dude Posted Image
think that may answer some of your questions rob
