From the research I have done the plastic bit is not the problem it is the bearing that causes problems is this correctwould be great to see this one on the list..
lower steering column plastic bushes are getting hard to find that have not been worn out , LH , LX and UC all the same item i believe ...
The list as requested
#76 _les_
Posted 20 March 2008 - 02:54 PM
#77
Posted 24 March 2008 - 10:25 AM
That is correct. The plastic retainer is usually ok. Just the metal bearing that is removable.
#78 _les_
Posted 24 March 2008 - 07:46 PM
We have the bearing part number 7805700Hi Les,
#79
Posted 24 March 2008 - 08:39 PM
#80
Posted 29 April 2008 - 11:47 AM
Could you tell me the time frame for the following 2 parts i am chasing:
1. LH/LX metal battery tray. i know the UC one has been made and was supposed to be for all but is slightly different to the earlier toranas.
2. LH centre console skeleton.
Cheers,
Phillip
#81 _les_
Posted 29 April 2008 - 12:58 PM
Battery tray no date probably not this year you may be able to use the us one as a repair sectionhi Les,
Cheers,
Phillip
LH console 2-3 months for first sample we have been having some tooling problems the we never expected
#82
Posted 29 April 2008 - 01:43 PM
Cheers,
Phillip
#83 _les_
Posted 17 May 2008 - 03:57 PM
LC LJ Front panel lower repair section sample AVALIABLE part number 2806685
LJ Crash pad awaiting sample approved available about 8 weeks
DECAL AIR CLEANER LC GTR "2600" sample approved available about 4 weeks
LC Tail lamp lenses sample over due
9945051 LX console awaiting sample expected in2 mths
The following parts are still on
m38109 RIM HEADLAMP LC RIGHT HAND
m38110 RIM HEADLAMP LC left HAND
m38113 RIM HEADLAMP LJ 6 CYLINDER
m38114 RIM HEADLAMP LJ 6 CYLINDER LEFT
m38115 RIM TAILAMP LJ L/H
m38116 RIM TAILAMP LJ R/H
#84
Posted 02 January 2009 - 11:32 AM
Happy NY to you. Any update on the LH centre console?
Cheers,
Phillip
#85 _les_
Posted 02 January 2009 - 03:37 PM
Hi Les,
Cheers,
Phillip
Hi Phillip
A happy New Year to you, on a not so happy note the company making these consoles for us has disappeared along with our samples and tooling. We are back a square one once we find another sample we will start again.
Les
#86
Posted 05 January 2009 - 09:27 AM
Cheers,
Phillip
#87 _les_
Posted 05 January 2009 - 09:31 AM
Les that is a shame. I don't know if I can help you. I have an LH console I can lend to you if required. Not an LX one though. PM me if you want to borrow it. Has a few cracks and missing the centre part (where the T-Bar goes) but might be fine for a sample.
Cheers,
Phillip
Thanks Phillip
I will keep that in mind I will try and buy one locally first as we really only need the bottom part
#88
Posted 21 February 2009 - 12:13 AM
#89
Posted 22 February 2009 - 07:38 AM
LH-LX CONSOLES ARE DIFFERENT ALONG THE BOTTOM TO HQ-WBRegarding the LH centre console, am I correct in believing that they are indentical to the HQ centre console?
#90 _les_
Posted 22 February 2009 - 09:05 AM
The HQ is also different on the top to the LH and the HJ HX HZ WBLH-LX CONSOLES ARE DIFFERENT ALONG THE BOTTOM TO HQ-WB
#91
Posted 22 February 2009 - 10:56 AM
