Wish List
#51 _Herne_
Posted 17 May 2006 - 06:13 PM
I will go get it tomorrow if my son is not working as right now I have no car
Herne
#52 _devilsadvocate_
Posted 18 May 2006 - 09:46 AM
That's disappointing Makka and again not helpful-my cotter pins are still stuck.As toranamat69 said, anyone with half an idea could make a cotterpin removal tool, i just did it with a hammer and a brick, and thats with a V8 in the way.
I suppose you are thinking that if rarespares spends time on the tool they'll have less time for you wish?
People are wishing for original type replacement battery trays, when there are plenty of plastic trays which will do the job............I dont have a problem with that either. Isnt this what the wishlists about?
If rarespares doesn't have the demand or ability to make the tool thats fine with me, no need for nasty comment from you.
Edited by devilsadvocate, 18 May 2006 - 09:58 AM.
#53 _TORANR AMORE_
Posted 18 May 2006 - 12:37 PM
devilsadvocate: If your having difficulty with the cotter pins, I can come over and show you how it's done if you like.
#54 _The Baron_
Posted 18 May 2006 - 01:09 PM
Les, I got a plastic tray a little while ago.
Why do they have the dimpled surface?
The edging is sharp and not squared of as per orig.
They feel brittal and hard.
Yes they are better than nothing but it appears that better quality control could have resulted in a better product.
I don't mind paying good money for a good product but I think this item is a little below par.
I hope you view this as constructive criticism.
Cause if RS don't get it right, they will be hard to shift for top dollar.
#55
Posted 18 May 2006 - 03:44 PM
DA, I've usually braced the steering shaft with half bricks and wood and hit the little buggers - and heated up the coupling with a bare flame from a gas soldering iron on occasions, but if yours are really stuck, can I suggest the following (and hope you can understand what I mean). I've thought about making it, but luckily I haven't met any cotter pins that didn't respond to a dose of RP7, gentle taps, and the odd heating up with a gas powered soldering iron.My only wish.........the cotter pin removal tool for steering couplings.
Would pay up to $100 to get one.
Get hold of one of the cheap general purpose steering wheel pullers, the type with a centre bolt through a cast steel piece which is designed to be tightened up against the steering column shaft. The cast steel piece has slots in either end for screwing bolts through, and into the steering wheel hub. Some I've seen have a thick collar (like a really thick washer) which fits onto the end of the centre bolt. This would be the best type to get.
Now, make up a flat plate out of strong steel about the same size and shape as the cast steel piece, with a hole in the centre that will fit over the non threaded end of the cotter pin while it is in the coupling. Drill holes in either side which lines up with the outer holes on the steering wheel puller. Find some nuts to suit the outer bolts supplied, and assemble the steering wheel puller around the cotter pin with the flat plate you made up on the non threaded end, cast steel piece on the threaded end, bolts through either side to tighten the two parts together, use the collar on the centre 'pushing' bolt to locate it centrally on the cotter pin, and tighten the central bolt. The cotter pin might still need a few taps, but I'd reckon that this setup would work OK. The plate that you make up would need to be reasonably strong though to stop it from bending, so maybe a bit of angle iron would do it instead of a flat plate.
Does that make any sense??
#56 _devilsadvocate_
Posted 18 May 2006 - 04:41 PM
Did actually try what you suggested a while back,(as Ive got a steering wheel puller), but couldnt find anything strong enough to fit(there's not much room around the back side for anything but the correct tool) to the back.......just succeeded in bending the metal brace in........might have another look at and see if I can get a heavy compact piece of high grade metal from a local trailer manufacturer made to the right size with appropriate sized holes etc.
#57 _les_
Posted 18 May 2006 - 07:16 PM
TORANR AMOREengine bay grommets are things that I also need.
Engine bay grommets as well as clips are high on the agenda we are collecting samples as we speak
Les
#58
Posted 18 May 2006 - 07:17 PM
Edited by Toranavista, 18 May 2006 - 07:17 PM.
#59 _les_
Posted 18 May 2006 - 07:32 PM
�Why do they have the dimpled surface?�
We have had great difficulty getting smooth plastic unless we buy unrealistic quantities
�The edging is sharp and not squared of as per orig.�
I think I know what you mean I will put an IR in on the product (I can not remember what IR means but it is used of products that have a problem maybe it means improvement require but it gets things happening)
�They feel brittle and hard.�
This will be covered in the IR
Thanks for the feedback
Les
#60 _les_
Posted 18 May 2006 - 07:36 PM
These are available from speciality tool suppliers and most spare parts stores could probably order one in for youHow about the tool for fitting the chrome Mylar windshield seal retaining strip?
#61
Posted 18 May 2006 - 07:53 PM
#62 _les_
Posted 18 May 2006 - 09:30 PM
Let me check tomorrow and see what I can findThanks for the reply. I spent a few hours today ringing around specialty tool shops and auto parts suppliers and panel beaters suppliers. No luck. I found one on ebay but not sure if the width is correct. I will have ago at making one. Carnt be too hard to make. Just thought it was a logical progression since you must sell heaps of the mylar strip.
#63 _The Baron_
Posted 19 May 2006 - 12:07 PM
#64 _LX406_
Posted 19 May 2006 - 04:22 PM
#65 _les_
Posted 19 May 2006 - 04:37 PM
Thanks I will add it to the list
Les
#66
Posted 19 May 2006 - 07:51 PM
#67 _Azza_
Posted 20 May 2006 - 05:18 PM
I wish for you to make a complete A9X Torana, and if it could be done by next weekend that would be tops.
Kind regards,
Adam
#68
Posted 20 May 2006 - 09:13 PM
Thats the whole pointGeez i dont think les will need to do any thinking about "what to make next" !! I think it'll be how are we going to make all this stuff!
Les doesn't have to THINK of things to make
We'll do that
He just needs to prioritise WHEN to make them
#69 _les_
Posted 21 May 2006 - 10:18 AM
AdamDear Mr Les,
Kind regards,
Adam
That�s a bit tough can I have a least 10 days
Les
#70 _Herne_
Posted 22 May 2006 - 10:05 AM
Les.Plastic Battery Tray.
I bit the bullet ordered and collected my battery tray a few days ago.
I dont mind the tiny dimple effect on the bottom of the tray and although I have not fitted the part due to my engine bay being stripped out but I do not think the dimples will show and even if they do they will not worry me.
I found the edging on my tray not to be sharp, maybe Barons one somehow slipped through a tad unfinished?
The problem I see is and here I totally agree with Baron it does appear that it could be very brittle. Time will tell but I thought the tray would have been made from a plastic material slightly more pliable.
Herne
Edited by Herne, 22 May 2006 - 10:08 AM.
#71 _les_
Posted 23 May 2006 - 12:49 PM
This took longer than I thought try one of our customers Oz Auto MouldsHow about the tool for fitting the chrome Mylar windshield seal retaining strip?
03 97058500
Les
#72
Posted 23 May 2006 - 01:43 PM
Thanks for your help Les. Tool is on its wayThis took longer than I thought try one of our customers Oz Auto MouldsHow about the tool for fitting the chrome Mylar windshield seal retaining strip?
03 97058500
Les
#73
Posted 24 May 2006 - 12:29 PM
And any idea what's happening with the 30yr promo dvd's? Was promised one ages ago and Leith isn't returning my e-mails... Grrr....
Dick
#74 _les_
Posted 24 May 2006 - 08:31 PM
DickG'day Les, how about a run of the full color, illustrated parts catalogue you had at the FastLane member's night??
Dick
There were some legal problems with the DVD�s I am not sure at stage we are at. Leith has been under the pump, we have just moved in to a new warehouse as well as the new shop and he is a long way behind and sometime very forgetful but he should answer your emails though I will have a chat to him.
If only it was viable to produce that catalogue I would love to
Les
#75
Posted 25 May 2006 - 05:45 AM
