LJ XU1 Numbers Please
#26
Posted 16 July 2011 - 12:32 PM
Two of the members from my car club,both have 5/72 xu-1's,and the both have december 71 heads,its there original heads.
Cheers John.
#27 _sunburst73-xu1_
Posted 16 July 2011 - 01:05 PM
Thanks John,Just more proof that some parts for theses car did sit around alot longer then the 3 month pryer thoery and were fitted from new.Hi Dane,
Cheers John.
cheers Dane
#28 _gtr-xu1_
Posted 16 July 2011 - 01:57 PM
#29
Posted 17 July 2011 - 07:05 PM
#30 _threeblindmice_
Posted 18 July 2011 - 02:43 PM
and the back set were cast at a different angle.
#31 _Skapinad_
Posted 20 July 2011 - 07:19 AM
#32 _sunburst73-xu1_
Posted 20 July 2011 - 10:32 AM
#33
Posted 20 July 2011 - 01:00 PM
Um, yeah, they are the impression of screw heads......so they were screwed in differently.I checked my H252 heads today ,one 11 H ,and one 12 H , and noticed the H looked a very little different , but the screw slots , at the H252 and
You will notice if you get a bunch of heads from the same mould that each one will be marginally different from the others.
The youngest head from that mould will have more meat in it...........
The moulds and dies wore out over time, one of the reasons (apart from volume through-put) that you run multiple sets.
Grant..
#34
Posted 20 July 2011 - 03:22 PM
Grant..
^^^^^ , from info I have read in years gone by, the patterns (moulds) for sand casting parts are often made of timber so the action of compacting the sand around the pattern would be quite abrasive and quickly wear away at the timber and/or any protective coating that might have been applied.
#35
Posted 24 July 2011 - 04:44 PM
Most 27F3 heads had larger valves that would come in handy for a Sunday drive in October.
To the left of the '2' there appears to be a 'K' - Kenny who worked at the foundry
#36 _Ozzie Picker_
Posted 24 July 2011 - 05:48 PM
A 27F3 9H cylinder head with standard LJ XU1 inlet valves.
thats interesting,wonder if Kenny did mine
small valve in that cast number,wonder what mike has to say about that.
#37 _sunburst73-xu1_
Posted 24 July 2011 - 05:54 PM
Very,very interesting Kockum, X2.I have never seen a K looking letter like that before,surely it wouldn't be the grain of the head that just came out like that. who knows.A 27F3 9H cylinder head with standard LJ XU1 inlet valves.
The other interesting comnet is about the inlet value on the 27F3 head,,,,,,,makes alot of sense them heads with the bigger values were only made for a particular motor and was argued on another thread that was a long long thread and has die down(thankfully), I don't want to mentioned that thread,(150)
Just go to show that them date coded heads were different depending on what motor they were made for.
cheers Dane
Edited by sunburst73-xu1, 24 July 2011 - 06:02 PM.
#38
Posted 24 July 2011 - 11:19 PM
I dangled a juicy scrub worm commenting on the 20F3 and 27F3 heads but did not get a bite - gone quiet just like the golden perch .
#39
Posted 24 July 2011 - 11:55 PM
if I get time tomorrow I will strip the paint off the 'K' area to have a good look .
20F3 heads -
If any exist with inlet valves like mine they would be far and few between .
All these that I have seen were fitted to the 'chosen cars ' or had been removed from one .
The less said about a certain thread the better - the vast majority of people are totally fed up to the back teeth with it .
#40 _BATHURST-32D_
Posted 25 July 2011 - 05:47 AM
cheers gong
#41 _sunburst73-xu1_
Posted 25 July 2011 - 08:19 AM
#42 _Ozzie Picker_
Posted 25 July 2011 - 06:57 PM
Craig , that is funny .
i read what you were saying in that thread,and that car and engine is precious,
#43
Posted 26 July 2011 - 12:14 AM
#44
Posted 26 July 2011 - 03:27 PM
What appeared to be a 'K' is just how the casting came out - the more paint you apply to that area the more pronounced the 'K' becomes .
Bugger .
#45
Posted 26 July 2011 - 03:38 PM
Thanks Craig .
I have seen all the photos that you posted of your beautiful orange beast .
What could be better than driving ONE of the 'chosen cars ' on any sunday !
#46 _Ozzie Picker_
Posted 26 July 2011 - 07:14 PM
Thanks Craig .
yeah cheers david,
it was a very special day to remember,
the xu-1 is a very responsive beast,not much gas and the neck flies back,pritty impresive considering the age of these machines.
#47
Posted 12 July 2012 - 06:08 PM
cheers anthony
#48 _LONA-CK_
Posted 13 July 2012 - 07:53 AM
I have owned every other lc xu1 heads but never kept the recored of the HHH
here are the other cast dates you need
may 1970
E140- XU1 cast on top of heads
E210
july 1970
G30
G90
jan 1971
A281-5H
A291
dec 1971
M21
the secret lies in the A291 and the M21 heads.
cheers gong
#49
Posted 13 July 2012 - 11:40 AM
cheers anthony
#50
Posted 09 August 2021 - 05:21 PM
