The larger the bore size the grater in brake pressure?
brake wheel cylindar bore sized
_Bathurst_stig_
, Jul 25 2011 09:07 PM
7 replies to this topic
#1 _Bathurst_stig_
Posted 25 July 2011 - 09:07 PM
Posted 25 July 2011 - 09:19 PM
Yes
Larger rear cylinders will give more braking effect
Smaller reduces... so if your having lock up issues you reduce... not enough you increase
#3 _Bathurst_stig_
Posted 25 July 2011 - 09:24 PM
Cheers mate
Posted 25 July 2011 - 09:26 PM
And will increase pedal travel.
Posted 26 July 2011 - 01:54 PM
the biger the bore dia the more fluid it takes to push them out and more peddle trave will be evedent.
you should have a better brakes with the correct size for which ever brakes you are running.
Posted 26 July 2011 - 02:27 PM
So was there a difference in bore size between the drum front and disc front models? If so, what size was what?
Posted 26 July 2011 - 03:21 PM
Not on LH (all 3/4)
Only on LC and LJ
And late UC ran Commodore cyls just to confuse things
Only on LC and LJ
#8 _nemo355v8_
Posted 07 August 2011 - 06:47 PM
Rear drums with disc fronts had 9/16 wheel cylinders and drums all round had 13/16 or 7/8s from memory
