Yella Terra head
#1 _shep3305_
Posted 31 July 2011 - 09:53 AM
Posted 31 July 2011 - 05:12 PM
Your head started life as as a 161 high compression head.
#3 _shep3305_
Posted 31 July 2011 - 07:03 PM
Thanks fasteh.. We pulled it off the motor this arvo and it doesnt look to bad.. My son is very excited as he now has the last piece for his driveline... Shame he doesnt get his licence for another 2 years lolI picture says 1000 words....but as far as we can tell there is no way to id YT heads...noone seems to know what the stamping means.
#4 _double_d_
Posted 31 July 2011 - 07:53 PM
beacause i have one here
and also a head i pulled off a worked 186
the valves on both heads seem to be the same size
would it be more that the 186 head i have has bigger valves then stock?
only real difference between the two is a bit of smoothing in the inlet ports and the usual sleeve for the bolts on the yell terra
daniel d
Posted 31 July 2011 - 08:37 PM
#6 _stretchlc_
Posted 02 August 2011 - 07:49 PM
Double Valve Springs are also fitted, as opposed to an outter spring and an inner dampener!
YT cast onto Valves as per pics......that is.......if it still has the original Yella Terra Valves fitted!
#7 _shep3305_
Posted 03 August 2011 - 05:46 PM
Thanks for the pics... It has double valve springs and oversized valves, i hope it will be a better head than stock.. Because its been identified as originally a high comp 161 head does that mean i have to use 186 pushrods on a 202?Heres a few pics of a Yella Terra Head to help you identify it-
Posted 03 August 2011 - 06:06 PM
