9 inch diff noise only when turning
13 replies to this topic
#1 _toranaddict_
_toranaddict_
Posted 02 August 2011 - 06:01 PM
g day in need of some help please
got a lsd 9 inch in a lh torana when im going in a straight line no noises but when turning the diff is making a banging noise quite loud, fill the diff with penrite 140 lsd oil and a lsd additive and still the same any suggestions would be appriceated thanks
#2 _rob350hatch_
_rob350hatch_
Posted 02 August 2011 - 06:28 PM
is it only new or is it an old diff.mine allways clunk around for a few weeks when new till they settle in
Edited by rob350hatch, 02 August 2011 - 06:30 PM.
#3 _Ozzie Picker_
_Ozzie Picker_
Posted 02 August 2011 - 07:52 PM
hi,
tell us a bit about how long you have owned the car,etc,has noise just started?
is it a clutch pack centre?
a detroit locker diff is very noisy,when turning
#4 rodomo
  • 17,998 posts
Posted 02 August 2011 - 08:53 PM
:iagree:
What is the full story? Did it have just normal diff oil in it before you drained and re-filled with LSD oil?
If so it will take a while for the noise to dissappear.
#5 ACJ
ACJ
  • 197 posts
  • Name:adam
  • Car:LH
Posted 02 August 2011 - 10:13 PM
I think maybe one wheel was in the gravel and the other on the bitumen. The brain forced the right foot down very hard for to long. Then loud bang and spider gear started losing teeth ????
#6 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 03 August 2011 - 07:58 PM
Pull it out, look at it. Only way really to be sure. No use trying to guess. it's not a big job and a good learning experience.
First guess would be it has a Detroit locker (or similar) in there.
Dave
#7 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 21 February 2021 - 05:46 PM
Hey Girls and Guys, I sent the 5ltr and the T10 box off for a rebuild. I dropped the oil out the diff, its a 9inch lsd. There were no problems prior. But after all was done , I noticed a binding noise from the diff. The noise is only when I turn (left or right). I did mark the tail shaft but didn't think to look for the mark when re installed. First I used Tanoa 80w-90 mineral gear oil API GL-5. I removed the diff and it all looked good but I am no expert. So I re installed the diff and used Brad Penn multi purpose gear oil SAE 80W-90 but its still binding. Can anyone give some advice . Rainman .
Thanks in advance
#8 dron
dron
  • 126 posts
  • Name:Darren
  • Car:UC
Posted 21 February 2021 - 06:35 PM
Hi
   Try LS90 or LS85/140 for HD use. 85/90 is good for an open center but not for a LS diff. the LS is the important part.
#9 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 21 February 2021 - 06:37 PM
Thanks Dron, I will give it a go Tomorrow and let you know how its goes. Ray
#10 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 21 February 2021 - 07:27 PM
Should I also ad an additive to LS 85W/140 ? Ray
#11 Redslur
Redslur
    Has been Torana owner
  • 3,532 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 22 February 2021 - 11:18 AM
Is it an LSD or Trutrac? Trutracs you must not use LSD oil. It has to be a 85/140 mineral oil. Not synthetic!
#12 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 22 February 2021 - 03:03 PM
Hey Gerry, its an lsd. Have dropped the oil and replaces with Castrol 85W-140 Axle lsd but still grabbing but not binding. Will this go away after a few weeks ? Does it need a good run to heat up ect ? Ray
#13 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 15 March 2021 - 12:06 PM
Hello Members, I added some lsd additive and the problem has gone. Thanks to all for there advice. Rainman
#14 Hell34
Hell34
  • 37 posts
  • Name:Peter
  • Car:LH ,UC ,HQ GTS 350, 94 Camaro 648 ci
Posted 21 March 2021 - 04:34 PM
 It’s probably a Detroit locker they do that
