Spark plug leads
#1 _mike_nofx_
Posted 23 May 2006 - 07:09 AM
Mike
#2 _devilsadvocate_
Posted 23 May 2006 - 07:50 AM
If the leads are physically damaged on the outside(check carefully around the plug/boot end as they d)eteriorate faster here due to the heat, then they can be the cause of the spark jumping to something else rather than the gap across the plug. The wider you make the gap on the plug, the better the chance of this happening.
A rather large thread was started....and finished on it around Jan if you want to go back and search.
Performance leads.....i dont think there was anything to show that they'll make the car go faster, other than subjective reports. Apparently though the insulation is of much better quality, supposed letting you handle spark leads while the motor is running and reduced em radiation in the radio band and lower resistance. Of course a defective set of regular leads replaced by high performance leads will always offer an improvement.
My 10cents, if the car is not "missing", and they dont exceed the resistance values.....save your money. They dont have to be replaced, one of my UCs still has all original leads, keep them clean by wiping all the grit and grease of with kero.
#3 _Yella SLuR_
Posted 23 May 2006 - 10:12 AM
Got the cable management system that goes on the side of the rockers. Found out that with such systems your No. 1 on the dizzy has to be somewhere between 7 O'Clock and 6 O'Clock when standing in front of the car for them to reach, not 12 O'Clock and 1 O'Clock like it is at the moment, otherwise some leads are too tight.
Edited by Yella SLuR, 23 May 2006 - 10:13 AM.
Posted 23 May 2006 - 12:29 PM
#5 _[BOTTLEDUP]_
Posted 30 May 2006 - 09:07 PM
As Devil has mentioned, anything over 15,000 Ohms per metre is bin time. For the record we only use MSD or Magnacore wire, the resistance of the MSD Super Conductor is the lowest on the market, at 60 ohms per foot, or appox 180 ohms per metre.
#6 _hrt1and2_
Posted 30 May 2006 - 09:20 PM
How much would a set of 6 cost ya?,May 30 2006, 09:07 PM] We make custom leads in house... Any length any terminal type.
#7 _70rey_
Posted 31 May 2006 - 09:40 PM
depending upon the size and company u go to
